Throttle Response Cam
I wanted to put on a Weltmeister throttle response cam but it says only for manual cars is there a difference that I cant install it?
I don't know why they would specify for manual transmission only...unless there is additional cable attached to the current trottle cam for cruise control.
Examine your current throttle cam assembly... Manual transmission cars have a single braided cable coming from the firewall (gas pedal) to the lever arm of the throttle cam. There is a return spring on the cam, and another return spring on the shaft. A single nut retain the whole assembly. If yours is like this...go ahead and replace the cam. The new throttle cam eliminates the lever arm, which gives the gas pedal a 1:1 ratio. i.e. you don't depress the gas pedal as far to rev the engine. JM
They're a waste of money.
95 240sx-track slut w/ too much done to list 87 944 n/a-old "toy" that broke too much |
There are two cables coming out of it.
Burn the fire.
Want more throttle? Remove the plastic bolt that sticks out of the stop for the accelerator pedal. Then continue to floor it.
[x] Working | [_] Broken: 2017 Victory Octane [x] Working | [_] Broken: 2005 Ram 1500 SLT w/5.7L Hemi "Drive it like you stole it." |
I'm off the hook.....
It's eye candy for your foot.
Gawd, I wish I had invented it. I'd be rich and fat!
No, I don't sing. Based there for too long. |
Burn the fire.
Need throttle response?
Stomp on the pedal quicker.
i got one of those installed and noticed no more throttle response than the stock setup. just looks pretty when you open the hood to find a different color other than aluminum and flat black
85/1 944 project/restore/upgrade in process finnaly: Bursch headers and cat delete pipe. fiberwerks front bumper and rear wing cant spell forgive my "hukt on Fonix" it workt gud four mi in the process of buying a car and a half garage with a detached house and fenced in yard 03 Eclipse GS |
yeah, auto tranny has a kickdown cable. and the mount is incompatable. totally different critter.
*Disclaimer: The person above is actually dumber than he appears. my web site Torque values maintainance and repairs lots of my rebuild pics weights and measurements '84 944 auto/ps/ac/cc '86 951 Providing ignorance one post at a time. |
