My NA uses app. 10~11L / 100km if I drive it fast. if slow it gets to somewhat 8~9L /100km
I use 100 octane gas only. |
My car seems to run good, but I only get about 20-23...and I live in the country, most of my driving is open road.. When i mash on it, i can smell exhaust, and there is some soot on the tail pipe.. whats the most common problem?.. The O2 sensor doesnt surge or pulse..
1987 Porsche 944 1971 Porsche 911E..(It went home,Germany!) 1969 Porsche 912 1964 Porsche 356c..(roller) 1988 Porsche 924S (PARTS CAR) |
winter-hater club member
vacuum leaks, bad O2 sensor, bad spark plugs, weak spark, bad FPR/dampener, leaking injectors.
2000 Corvette - ????, 2007 Buell XB9R - Astrid, 1996 Discovery - Piglet, 2000 Forester "COOL PRIUS!" - Nobody Ever |
Is it possible for the injectors to "dribble" into the cylinders after I park it? IThe car runs pretty good, but sometimes after it sits for a coupled days, when i go to start it , it runs rough and then smooths out after a couple minutes... if it smokes any its very faint black or grayish.
yeah, they can. also, the backflow valve at the pump may be bad, or the cold start equipment isn't working right.
Well it starts easy, crank a few times and it starts right up, just after a few days sitting it idles rough and smoothes out, once warm it idles fine. I think I'll check out the o2 first. Already changed the plugs and airfilter and such.
I tried to get the O2 out, no luck!! its really in there, I even went and bought a tool... it looks like its been in there a while. I'd say theres a good chance its bad.
they can get good and stuck, for sure.
Any tricks to getting them out? I am afraid i'll take the threads out with it.
dose it really good with penetrating oil, let it sit overnight and try again. i doubt you will take the threads out, but it is a worry.
I took the threads out of a BMW once, kinda gun shy about them now.
no matter how i drive my '87 NA i consistently get 23.0-23.6 mpg, not that great.
1991 cabriolet (sold) 1989 S2 1988 S 1987 944 n/a (sold) 1987 944 factory yellow (junked )
Coming up on your left...
I average around 22 with my 951. If I engage the turbo WOT, it dips down significantly.
1986 Porsche 944 Turbo "S" clone ![]() 1998 Honda Accord ![]() Siena College '08 Manager, Mavis Discount Tire
I get about 25 pr gallon but I also drive like a fool most of the time. Its so much fun to drive fast that i can hardly test it going a normal speed hehehehe
Dave 1984 944 N/A Black (Daily Driver.) New Users please add your car's year and model to your signature line! |
Do you MPG gauges factor into this at all? Are you doing miles/tank by absolute values on the odometer? I'm asking because I wish to know if the MPG meter is accurate within a few MPG or whether it's just for fun to watch bob back and forth.
i get about 16 MPG in the city, due to my heavy foot and boost-dependence (its a problem, but i am not seeking help!). on the highway, averaging 80+ MPH, i get about 26-27 MPG.
Just thinking out loud
25 with the A/C on, 31-32 off, mixed. Not a lead foot.
83 944 91 FJ80 84 Ram Charger (now gone) |
OK, I got my O2 sensor out today, will change it tommorrow, i talked to my brother he said it might be the coolant temp sensor....he seems to think it would make more of a gas mileage difference than the O2.. Any thoughts about this?
yeah, it could. if it was 'stuck' reading that things were cold, i guess the computer would be constantly dumping fuel to make things rich for cold running.
