Send a message via AIM to sreece
Possible to add '87 944 Turbo to an '87 924S?
Is it possible to take a Turbo setup from an '97 944 Turbo and retrofit the parts to a 924S? Would have pretty much all the Turbo parts to include K26, intake/exhaust manifold, crosss/down pipes, wastegate, exhaust, intercooler, air flow meter, DME, etc. Is this a realistic solution to add a turbo to the 924S. How much of a difference is there between the 87 944 and 924S engines? I know they are both the 2.5L but not sure about the subtle differneces that could cause a problem.
___
'87 924S
Black on Black
Old 10-29-2004, 06:26 AM
ae1969's Avatar
Send a message via ICQ to ae1969
The block is the same, but the turbo runs forged rods, pistons, different compression, then you need the drivers engine mount (oil return/support) etc..etc.. ........
Unfortunately its not a bolt on project. It is quite involved.
You are much better of getting a complete turbo engine. If you search you will find many reasons why you shouldn't do this.
.... and welcome!
Alex - PCA Polar Region - Boxster Muncher
86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD
www.edmontonhomelife.com
www.edmontonrealestate.ws
Old 10-29-2004, 06:44 AM
Zero10's Avatar
Send a message via ICQ to Zero10
In 87, the 2.7L was available too, other than that, the 2.5L in the 944's is the same as the 2.5L in the 924S. Except perhaps the fuel rail configuration. I believe the 924S used the later DME, and therefore had the second temp sensor.
Now, about the turbo part.... that's something that seems to come up every 3 or 4 weeks, and it never gets a warm reception.
Long story short, buy a turbo.
small typo, I think you mean 87 944 turbo.
You also need to remember, there is a lot more to a turbo than the engine, suspension, fuel pump, and probably a dozen other things I've forgotten about.
You would also need a full set of heat shields.
Correct me if I'm wrong, but I believe the nose panel on the 924S is welded into place, just like the early 944's. Which means you'll have a tough time getting the intercooler in.
2010 Hyundai Elantra Touring, GLS 5 speed, Indigo Blue Metallic. 2.0L of Korean fury!
Buy my parts!
Old 10-29-2004, 06:46 AM
Thanks, guys. I think you have talked me out of the conversion. I probably could have all the parts needed, however, it sounds like I may run into many unforseen problems. Too many to worry about. I appreciate your support and I'm sure I will have many more questions.
___
'87 924S
Black on Black
Old 10-29-2004, 07:42 AM
Did you have an entire 951 at your disposal? Or just a pile of parts? I think a 951 drivetrain in a small 924 body would be one of the ultimate sleeper cars. Unfortunately, you'd have to transfer ALL of these parts over:
Hmm, they left out the two DME/KLR computers, injectors, fuel-pump, wiring-harness, intercooler-pipes, etc...
Old 10-29-2004, 07:30 PM
Dog-faced pony soldier
Porsche-O-Phile's Avatar
With enough time, money, a welder and a sawzall, anything can be made to fit anything else.
Black Cars Matter
Old 10-30-2004, 08:14 PM
Just knew of a guy who was autioning a complete parts kit from a 951 to switch a non-turbo to a turbo. Basically was selling all the parts needed as a kit. It has been sold already and I did not purchase it. Not sure what other parts he has. I have a 924S which has the non-turbo 944 engine already in it, I was just wanting to get a bit more power but was not sure how the non-turbo engine would run with a turbo built for an engine with lower compression.
I have a buy a work here that has a 350Z track model that he has been racing at the local autocross. He wants me to join up and he is having a hard time beating a 951 who races. I wanted to be able to compete.
___
'87 924S
Black on Black
Old 11-01-2004, 05:53 AM
