AllPorsche944's Avatar
Porsche Crest Need Tech Feedback
Greetings: I have finally installed my rebuilt motor and suprisingly she started right up. After some fine tuning (fuel leaks, vacum leaks,etc) I think it is about right...HOWEVER...it still seems to be idling a little rough and I can hear the air flow meter "hissing" as if it is gasping for air...Here are some of the things I checked:
> Fuel Pressure = Right at 37 PSI
> Air Flow Meter is brand new
> Checked Spark Plug Gaps (Replaced with New Silverstones)
> Checked for any added vacum leaks and there appears to be none
> Idle speed is right around 950
....Can't seem to figure what the problem could be...Air/Fuel Ratio off? If so, how do I adjust?
This is all for an 88 na...Thanks as always
88 944na = Azure Blue
New Rebuilt Race Engine (@190 HP)
Lindsey Racing Fuel System
MSD Ingnition System
Zimmerman XDrilled Frt/Rear
BB Headers & Cat Back Exhaust
Mass Flow Air w/ Ingen Technology
Nology Pro Fire Wires & Coil
Millie Cup Wheels and Kuma's
Old 11-29-2004, 03:49 PM
Mike B's Avatar
Sounds like you may have missed a vacuum leak.
'86 951
'88 928S4 - the project
Old 11-29-2004, 04:02 PM
ae1969's Avatar
Send a message via ICQ to ae1969
MIkeB is right....... (how have you been mike! Long time no hear!)
Also take a look at the hoses underneath the intake........ the ones coming from the idle stabilizer valve to the manifold...... the fat hoses. These like to split.
Alex - PCA Polar Region - Boxster Muncher
86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD
www.edmontonhomelife.com
www.edmontonrealestate.ws
Old 11-29-2004, 04:09 PM
fast924S's Avatar
Send a message via AIM to fast924S
You can try spraying some brake clean around the intake or where you think the leak is, If there is one it well raise the idle when it sucks in the brake clean. I would just double check everything
1986 951, Stock for now.
]87 924S Gaurds red- SOLD after 11 years of ownership
Old 11-29-2004, 06:13 PM
bryanthompson's Avatar
Send a message via ICQ to bryanthompson
^--- and keep a fire extinguisher handy!
1983 944 - Sable Brown Metallic / Saratoga / LSD : IceShark Light Kit
Old 11-29-2004, 06:21 PM
fast924S's Avatar
aaahhhh yea I left that part out, Thanx for getting my back on that one man
Old 11-29-2004, 06:22 PM
