seaboltman's Avatar
Gear Indicators dont light up.
Well, i've got an Automatic 86' and on the gauge cluster is the thing that lights up and indicates what gear you are in. Well it stopped working. Im not getting any sort of lights from it. All the other gauges appear to work though.
Ontop of that i noticed that if im in reverse i have to wiggle around the gear lever in order to get the reverse lights to turn on.
When im in gear, I can wiggle the shifter about 1/2 inch or so with no problem. I dont know if thats common or not, figured I would throw it in.
Any help? Im hoping that i can just clean up the grounds and be done with it, but anyone else ever had anything similar to this?
1987 944 - Wrecked turned parts car
1986 944 - Awesome Auto
Old 11-24-2004, 08:51 PM
Mein Gott!
Panzer909's Avatar
Yeah, its common with any car approaching 20 years old.
Grounds will get sensitive, but in the worst case scenario you'll just have to relpace a bulb behind the dash. I had to do this once and luckily the car comes with extras behind the dash panel. Either way, its not a big issue to fix. Clark's Grarage has a great how-to on pulling the dash cluster if you never did it before.
Johnny
1987 944S
1984 944 (R.I.P.)
1972 Triumph TR6 - 100% trouble free between breakdowns
2003 BMW 325xi
Old 11-24-2004, 11:29 PM
livewirevoodoo's Avatar
on autos, also check under the shift boot. There is a contact underneath that based on the position of the shifter displays what gear your in. Mine doesnt light up b/c the little spring that pushes and pulls the contact broke. A .25 cent part I'm sure, but damned if i could find a part number.
''87 944na 85k
C02 / M158 / M418 / M425 / M431 / M454 / M533 / M650 / M946
'94 Oldsmobile 88 Royale (winter beater)
Its not what you drive, its what drives you.
Old 11-24-2004, 11:40 PM
Dog-faced pony soldier
Porsche-O-Phile's Avatar
Awwww. . . just chuck it an put in a 5-speed or 6-speed manual.
*ducks*
Black Cars Matter
Old 11-25-2004, 11:05 AM
seaboltman's Avatar
im thinking about it if i manage to save up enough money to get a lightweight flywheel over the winter break, then ill buy one and put the trans out of my parts car in there.
Old 11-25-2004, 11:13 AM
DumasDemon84's Avatar
Contact spring
I just replaced mine a couple of weeks ago. I got one on E-Bay for $3. Anyway on my car, the only ones that don't light up are Park and Drive, all the rest work. Here's the part number:
Porsche 944 contact spring part no. 94461362101
I hope this helps.
1986 Guards Red 944 Auto
1995 Chevy Tahoe 3-3 drop, w/ 22's
2006 GMC Envoy
1989 Dodge Shortbed(project)
Old 11-29-2004, 06:12 AM
seaboltman's Avatar
Thanks alot
Old 11-29-2004, 06:25 AM
Dumas - you solved a problem which has been naggin at me since july! thanks a helluva lot.
ya know how much it sucks to have to count gears in the dark?
''87 944na 85k
Old 11-29-2004, 08:24 PM
