Odometer broke - How do I take it apart
Ok I got the cluster out and the then the speedo out but I can't get the cover off I've tried for hours how the hell do you do it???
I have an 84. |
Are you sure it's not the cable?
Otherwise you have to pry the steel can open around the plastic lens. Don't have to get it wide open, a little all the way around will do it.
Hugh - So Cal 83 944 Driver Person NOT a 'real' Porsche -- Its Better!!!! When was the last time you changed your timing and balance belts and/or cam chain and tensioner? New Users please add your car's year and model to your signature line! Never break more than you fix! |
