944 Difficult to fill with gas
I have a 1990 944 S2 Cabriolet that is extremely difficult to fill with fuel. The pump nozzle keeps kicking off no matter how slow you try to fill.
Anyone heard of such a problem? I can stick a 1/2-inch vinyl hose down the filler tube about a foot before is comes to a springy stop. Is the an anti-siphon coil spring down there causing too much restriction?
Old 03-07-2005, 04:47 PM
maybe your full??
1988 924s mars red
coastal cruzer
Old 03-07-2005, 06:52 PM
Send a message via AIM to AznDrgn
about 1 foot in is where the rubber hose ends and the rubber coupling bends and enters the tank. Make sure your vents are hooked up and not clogged.
'91 Jeep Cherokee 4.0L HO - Daily driver
'83 Callaway 944 2.5L turbo - Soon to be daily driver
'83 Porsche 944 NA - sold
'78 Porsche 924 NA- RIP
'89 Porsche 944 S2 - Parted
Looking for a nice 944S for a daily driver.
Old 03-07-2005, 06:59 PM
Are the vent line(s) only accessed from the trunk? I see what looks like a rounded access cover under the trunk-hinge area that is screwed and pretty well weather-sealed in place. Before I attempt to peel that cover out I want to know that it will lead me somewhere useful. Thanks for your input, AznDrgn.
Old 03-08-2005, 08:05 AM
Zero10's Avatar
Send a message via ICQ to Zero10
Anti-siphon coil spring? I did not know our cars were equiped with one. How exactly does it work?...
I find with a lot of gas stations, the angle of the bend in the nozzle doesn't match the bend in the neck of my tank, and it sprays right against the bottom of the tube, and keeps shutting off.
I have to only put it in an inch, maybe 2 or else it will shut off every 5 or 10 seconds.
2010 Hyundai Elantra Touring, GLS 5 speed, Indigo Blue Metallic. 2.0L of Korean fury!
Buy my parts!
Old 03-08-2005, 08:26 AM
bryanthompson's Avatar
Send a message via ICQ to bryanthompson
Same here, Zero.
1983 944 - Sable Brown Metallic / Saratoga / LSD : IceShark Light Kit
Old 03-08-2005, 08:30 AM
If it's in the center of the hatch area, thats access to the fuel gauge sender.
Rick
99 996C4
06 525XI
87 944S - Sold
77 924 - Sold
Old 03-08-2005, 09:06 AM
Custom User Title
rammstein's Avatar
same for me too. Put it in only about 2 inches, and you should be fine.
Old 03-08-2005, 10:10 PM
livewirevoodoo's Avatar
Sounds like something my girlfriend would say.
''87 944na 85k
C02 / M158 / M418 / M425 / M431 / M454 / M533 / M650 / M946
'94 Oldsmobile 88 Royale (winter beater)
Its not what you drive, its what drives you.
Old 03-09-2005, 05:38 AM
Custom User Title
rammstein's Avatar
I was waiting for that!
Old 03-09-2005, 01:15 PM
Zero10's Avatar
Oh dear... I won't touch this one, let's keep it car related guys
Buy my parts!
Old 03-09-2005, 01:27 PM
Thanks you all for advice. I'll try the "partial-insertion" technique and let you know what happens.
As for the anti-siphon coil spring, Zero10, it would be a conical spring with the large end big enough to hold it in place in the fill tube and the small end tight enough to keep a hose from fitting through. I've never seen or heard of one being factory-installed, and with the unleaded-nozzle fitting on all newer cars, it would be impossible to install as a DIY item.
Old 03-10-2005, 12:35 PM
