'77 924 Martini--cold start/run problem
-------------------------------------------------------------------------------- I'm figuring that I need a Warm Up Regulator, as it is very difficult to keep it running until after it warms for at least 3-4 minutes. Also, I read that the early 924's came with a fuel distributor that was faulty and should be upgraded to it's replacement. I have 2 questions : --How do you tell if you have the faulty FD or if it's been replaced? --Would a Volkswagon warm up reg. for A1 & A2 possibly be the same part? They look identical. I saw one on ebay. Or, does anyone have one that you'll part with? Attached Images __________________ '77 924 Martini Edition '86 BMW 325e '90 BMW 735i (sold the 944 and the 911)
1990 bmw 735i 1986 bmw 325e 1970 porsche 911T |
I have an Audi Warm Up Regulator on my 924. All my research suggests that the system and crontrol pressures were the same for all cars that ran CIS. I will eventually be taking the Audi WUR off and replacing it with a rebuilt WUR I bought for about $100 but thats a few weeks off. When I do if you are still interested I would let the Audi part go for like $30.
Porsce did make changes to the fuel distributors in later model cars. I dont think that the early fuel distributors were faulty. The plumbing on the lower half of the distributor is different. I think a solinoid was added to help with warm starts. Upgrading the fuel distributor would be extremly expensive unless you find a used one. If the fuel distbutor isnt causing you problems dont mess with it.
Roger Hall 81 924 N/A Some people are like Slinkies. Not really good for anything, but you still can't help but smile when you see one tumble down the stairs. |
Check your grounds first, mostly the ground from the battery to the body and then motor. Lots of vw's have ground issues that cause all sorts of weird behavior (including cold start problems), maybe the 924 is closely enough related to vw's to have similar problems?
