Need an Idle Speed Valve
im sick and tired of the rpm going all over the place. Im quite sure its the ISV cuz if i smack it the rpms go to normal. Anyone have one for sale. Whats invovled in installing a new one.
88 928 S4 Black, Black and Grey Interior Alpine head unit & amp, Bazooka Tube, Viper 5704 Smart Start GPS tracking, Devek Headers, Flowmaster 40 3" with Resonator, Auto Authority chips. Custom Luggage Cover. Traded - 86 944 Turbo Guards Red. RIP - 85.5 944 Guards Red |
Im assuming your talking about the cold start valve? If it gets stuck open then your RPMS will rise, Anyway, I think you will need to remove the intake manifold since it is located under there. Other than that its not really hard at all.
1986 951, Stock for now. ]87 924S Gaurds red- SOLD after 11 years of ownership |
You have to jumper between pin B and C on the diagnostics plug before you set your idle. Otherwise it just wanders all over the place.
Hugh - So Cal 83 944 Driver Person NOT a 'real' Porsche -- Its Better!!!! When was the last time you changed your timing and balance belts and/or cam chain and tensioner? New Users please add your car's year and model to your signature line! Never break more than you fix! |
SoCal I tired the bypass...it simply doesn't work. I jumpered the B and C like Clarks Garage sugggests but it does diddly squat...is there another way to jumper it.
How did you adjust the idle after you jumpered between B and C?
Anyway, since you can hit the idle control valve you know it's under the intake. Some find it necessary to remove the intake to get to the valve. Others have reported they have R&R'd the valve with the intake on. Once you get it off just give it a good soaking with PB Blaster then Carb cleaner. Check all of the vacuum lines before you put it back on.
Hugh - So Cal 83 944 Driver Person NOT a 'real' Porsche -- Its Better!!!! When was the last time you changed your timing and balance belts and/or cam chain and tensioner? New Users please add your car's year and model to your signature line! Never break more than you fix! Last edited by SoCal Driver; 04-13-2005 at 07:51 AM.. |
And you might want to replace the o-ring on the idle bypass screw.
After jumping the B&C terminals...I adjusted the idle using the idle screw on top of the throttle body as depicted in clarks garage. But it doesnt do much as far as helping at all cuz eventually the ****in thing goes back to 2k rpm. I'm ready to drive this thing into a wall.
WTF is the idle bypass screw...is that the same as the idle adjuster screw
Yeap.
Check the setting for the TPS. Which trottle body is this?
um 85.5 na throttle body...well i ordered the idle speed valve should get here by friday...thanks for ur help
May be the DME.
