Send a message via AIM to drfatz
Drive Train Noise....
I just finished replacing the clutch on my 85.5 944 (after way to long). I used the pelican superclutch pack so all major wear parts have been replaced. I also installed a Fidanza Flywheel, a Lindsey Racing solid transmission mount, and rebuild drive axles/CVs. So...I have noticed substantial "gear" noise coming from the transmission/drive train. I think this is because I installed the lightweight flywheel and solid trans mount, but I figured I would ask you guys before I ruined something in the drive train.
1985.5 944 NA
-Racing Headers, Cat-less Borla exhaust, New racing Cam, Turbo valve springs, multi angle valve job, big bore throttle body, Eprom, blue printed injectors, throttle response cam,
-Just installed: M030 Suspension with turbo A-arms and hubs. Big Reds with rotors and stainless lines. Turbo sway bars front and rear. Boxter wheels, turbo mater cylinder, and MOMO steering wheel and shift knob.
Just Finished: Clutch, flywheel and transmission...and TONS more!
Old 07-18-2005, 06:45 AM
SoCal Driver's Avatar
Solid transmission mounts. Why do you think they were rubber?
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 07-18-2005, 09:09 AM
Oh I don't mind the noise at all...in fact I think its rather cool...I just wanted to make sure my transaxle/torque tube wasn't going to fall out :-p BTW the solid mount may convey more noise, but it makes shifting a lot smoother and more precise.
1985.5 944 NA
Old 07-18-2005, 10:13 AM
Fixing the worn pin in the shift lever helps more than mounts. Then when you put the short shift on it and start jamming the syncros you can learn to repair the trans.
Old 07-18-2005, 12:21 PM
1985.5 944 NA
Old 07-18-2005, 01:42 PM
