Rough idle and stalling in neutral
I have an 83' 944 manual transmission. My car idled rough in neutral from 900 to 200 back and forth until it would stall out and die. One day i tightened the throttle cable by twisting the metal hexagon edged piece connected to the rubber hose which incased the cable. Problem solved. But suddenly, 2 months later, im getting the same problem again. Intermitently its idleing rough in neutral. Any answers on how to fix this? I tried tightening the cable again but that didnt help.
Ive replaced the spark plugs, transaxle fluid, and oil filter recently. Also, when i was in line at the drive through everything was fine...but i seemed to be idling around 1000 instead of 900 and i just tapped the dash with my finger, i heard a quiet noise like a fan turning on and the neutral rough idle started right up. Maybe thats just some weird coincidence though. Last edited by pearljaman31; 08-01-2005 at 09:09 AM.. |
You may need a new ISV.... a friend of mine with a 85.5 had the same thing going on untill he replaced the ISV and most of the vac lines-good luck
Patrick '87 944NA - back on the road '83 944 - dearly DE-PARTED it lives on in 43 cars in 4 counties |
ISV?
1983 Porsche 944 |
idle stabilizer valve?
Still looking for the right deal on another P-car 1968 BMW 1600 2 liter 1956 Ford F250 1955 BMW R69 1999 Range Rover Callaway #011 of 220 (Yeah, as in Callaway Corvette...) |
'83 doesn';t have ISV. Thats a 85/2 thing. If you have throttle cable too tight, the TPS sensor can't go to "idle" mode. with engine off, you should hear a click if you move the throttle cam. if not, loosten untill you do.
*Disclaimer: The person above is actually dumber than he appears. my web site Torque values maintainance and repairs lots of my rebuild pics weights and measurements '84 944 auto/ps/ac/cc '86 951 Providing ignorance one post at a time. |
Well I learn something every day
