Rough idle and stalling in neutral
I have an 83' 944 manual transmission. My car idled rough in neutral from 900 to 200 back and forth until it would stall out and die. One day i tightened the throttle cable by twisting the metal hexagon edged piece connected to the rubber hose which incased the cable. Problem solved. But suddenly, 2 months later, im getting the same problem again. Intermitently its idleing rough in neutral. Any answers on how to fix this? I tried tightening the cable again but that didnt help.
Ive replaced the spark plugs, transaxle fluid, and oil filter recently.
Also, when i was in line at the drive through everything was fine...but i seemed to be idling around 1000 instead of 900 and i just tapped the dash with my finger, i heard a quiet noise like a fan turning on and the neutral rough idle started right up. Maybe thats just some weird coincidence though.
Old 08-01-2005, 09:06 AM
You may need a new ISV.... a friend of mine with a 85.5 had the same thing going on untill he replaced the ISV and most of the vac lines-good luck
Patrick
'87 944NA - back on the road
'83 944 - dearly DE-PARTED it lives on in 43 cars in 4 counties
Old 08-02-2005, 10:57 AM
ISV?
1983 Porsche 944
Old 08-02-2005, 04:49 PM
pokey's Avatar
Send a message via AIM to pokey
idle stabilizer valve?
Still looking for the right deal on another P-car
1968 BMW 1600 2 liter
1956 Ford F250
1955 BMW R69
1999 Range Rover Callaway #011 of 220 (Yeah, as in Callaway Corvette...)
Old 08-02-2005, 06:21 PM
todwic's Avatar
Send a message via AIM to todwic Send a message via Yahoo to todwic
'83 doesn';t have ISV. Thats a 85/2 thing. If you have throttle cable too tight, the TPS sensor can't go to "idle" mode. with engine off, you should hear a click if you move the throttle cam. if not, loosten untill you do.
*Disclaimer: The person above is actually dumber than he appears.
my web site Torque values maintainance and repairs lots of my rebuild pics weights and measurements
'84 944 auto/ps/ac/cc
'86 951
Providing ignorance one post at a time.
Old 08-03-2005, 11:04 PM
Well I learn something every day
Patrick
Old 08-04-2005, 05:04 AM
