ot timing question
I finally think i got my firebird running properly but while i had the scanner on i notice it said my timing advance was somewhere in the 20s. Is this normal for the scanner to say while its running or is my timing WAY off? I think it is being it knocks every now and then.
Old 08-10-2005, 04:08 PM
winter-hater club member
nynor's Avatar
you probably ought to look in the manual. my guess is that the advance shouldn't be much over 15 degrees. also, i do believe that over-advancing will cause knocking/detonation.
"COOL PRIUS!" - Nobody Ever
Old 08-11-2005, 09:53 AM
can timing be set using the scanner though or do i need to find a timing tight?
Old 08-11-2005, 11:04 AM
nynor's Avatar
you said this is a firebird? what year, engine, etc.?
Old 08-11-2005, 11:09 AM
91 3.1 mpfi
Old 08-11-2005, 12:00 PM
nynor's Avatar
don't know about the newer american iron. does it have a distributor (yeah, i know nothing about this thing)? have you looked at a manual.
Old 08-11-2005, 12:04 PM
