Writer/Teacher
swaybar droplink upgrades
In my daily eBay travels I came across this auction, for upgraded swaybar droplinks. The only way I would buy such a thing is if I upgraded my rear sways, but I was wondering if anybody knows whether or not the upgrade would be worth it.
Current Stable: Black 07 Porsche 987 Cayman S: Long-Tube Headers; FabSpeed Exhaust; VividRacing ECU Tune; IPD Plenum; 997GT3 Throttle Body. Blue 1983 Porsche 928S. 1985.5 Porsche 944 Rat Rod. 2011 Acura MDX. 2008 Mazda 3. Gone But Not Forgotten:Garnet Red 86 Porsche 951("The Purple Pig"). Alpine White 83 Porsche 944 ("Alpine Wolf"). Guards Red 84 Porsche 944. |
disgusted
I bought some of those when he offered them the first time on Rennlist. From what I always understood about adjustable droplinks is that they are intended to take preload out of the sways, but the way some of the folks on the list where using them was to preload the sways so they come into effect more quickly. In any case, they are a tiny bit longer eye-to-eye than the stock dogbone links so I think they actually introduced a bit of preload when I installed mine. My alignment is so bad right now though that it is hard to tell if they did anything.
Michael Manning 95 Independent Fabrication Deluxe You are not what you own! |
Wonder how long that rod end will last on the road. Lots of grime and water.
Hugh - So Cal 83 944 Driver Person NOT a 'real' Porsche -- Its Better!!!! When was the last time you changed your timing and balance belts and/or cam chain and tensioner? New Users please add your car's year and model to your signature line! Never break more than you fix! |
disgusted
Yeah, I wonder the same thing. That's why I kept the original dogbones.
Composite Shop Owner, DJ
They are aircraft grade HEIM Bearings. One female and one male with an AN check nut. You can get them through most aircraft suppliers. Whether or not the ones he is selling are metric, I don't know. Or even if they need to be metric. They'll last for a while, but you should service them oftem with some lithium lube or something to keep them from seizing up. Use these all the time for the aircraft we build at our shop.
'86 944, 5 Speed (Daily Driver) |
You dive aircraft on dirt back roads with the oil from the engine and other cars sticking all over them? Do you then drive through inches and inches of rain forcing the grit and oil into the spherical bearing surface? How many hours between replacement on an aircraft?
There is a reason for the cast steel and welded link and rubber bushings on cars. I think these links are great for a track car where everything is checked the Monday after the race.
I knew I should have edited my comment to include the use of these as being good for track use for fear of someone being a smart f**t and flaming me.
Flaming? Just pointing out some serious short comings on the spherical links.
Have used same rod ends for panhards on bagged minitrucks. They squeak after a while because spherical bearing dry out.
You have a valid point SoCal.
1993 964 C2 still makes me smile Retired and work as needed as a pain in the **s. |
Writer/Teacher
yeah i can see how they would be better suited to track use
Used then for years and years in automation linkages. Have to get the ones with the grease zerts. Then hope the maintanence crew follows the schedule.
