cchyper's Avatar
Send a message via AIM to cchyper Send a message via Yahoo to cchyper
O2 sensor
My car is running a little rich. I know this because of my caked plugs. I just ordered a FRWilks Chip. I am hoping that this helps out a lot, BUT i was wondering if I should replace the $150.00 O2 sensor. I am eventually going to a header back exhaust but should i buy this o2 sensor from pelican just to be sure that mine isnt bad? I will see what happends with the chip install.... but i have a feeling that this alone will not solve the problem.
Old 09-26-2005, 12:44 PM
You need to fix the running fault before doing any modifications. If the pugs are caked then fix that.
From November 2012; Precision Porsche Specialist
Sussex UK, +44 (0)1825-721-205
2001-2012 Gerber Motorsport Inc. 206-352-6911
07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red
08.16.09 1999 Kawasaki ZRX1100. Green.
Old 09-26-2005, 01:01 PM
ae1969's Avatar
Send a message via ICQ to ae1969
You can buy a bosch sensor from any local parts stores......
Search here for the part number
Alex - PCA Polar Region - Boxster Muncher
86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD
www.edmontonhomelife.com
www.edmontonrealestate.ws
Old 09-26-2005, 02:00 PM
RIchard944's Avatar
Re: O2 sensor
FRWilk's Chip does not use the O2 sensor.
1989 Porsche 911 Carrera
1984 Porsche 944 (with PowerProm & dual chip adapter)
Old 09-27-2005, 05:56 AM
cchyper's Avatar
Really.. the FRWilks chip doesnt need it?! ... thats good to hear, i guess that means that i can put a new exhaust on without a o2 sensor then! Is that correct?"
Old 09-27-2005, 11:31 AM
cchyper's Avatar
How do I lean it out... i will check the factory manual, but does anyone know the steps?
Old 09-27-2005, 11:34 AM
Byron T's Avatar
I'd check o2 sensor first. it has 3 wires, one will be 12v power one will be a ground and one should give you about .5v with car running. the .5 should fluctuate(?) from about .3 to .7 if it's good. Check these with volt ohm gauge. better if you have a digitail with graph to watch volts. if it's not moving (voltage ) o2 probably bad
Old 09-27-2005, 11:51 AM
Firstly, you don't just "lean it out" Motronic systems rarely go out of adjustment so you diagnose and then repair. Find the fault fix it, that easy!! Disconnect the 02 sensor if you want to check it...the engine will run slightly rich, but not rich enough to cake the plugs.
Bearing in mind the number of times we've seen dead 02 sensors, and that haven't worked for more than a while, I wouldn't class it as the #1 cause of problems..only to pass emission tests do you (usually) need to work.
If the engine has a vacuum leak the voltage reading will be wrong too..lots of possibilities...
Old 09-27-2005, 05:28 PM
cchyper's Avatar
I C
well i guess that i should check it then. Should i not install the frwilks chip until i find a problem?
Old 09-27-2005, 08:44 PM
winter-hater club member
nynor's Avatar
exactly.
"COOL PRIUS!" - Nobody Ever
Old 09-27-2005, 08:57 PM
