Tapage's Avatar
Send a message via ICQ to Tapage Send a message via AIM to Tapage Send a message via Yahoo to Tapage
Huge Clutch problem ..
Hi all folks ..
This is the 3rd time with this issue, all times new, disk, pressure plate, flywheel, push rod bearing and fork ..
all times my local Porsche master pay for it .. but isn't a money issue .. we have a problem and not yet a solution.
OK this is issue, 3 times my 951 do the same thing .
3 times very similar .. the first time we have a splines axle issue related .. and put a new axle, and disk.
2nd time, we thought bad conbination of pressure plate and disk, new ones with bearing, and fork, flywheel OK .. this time I have maybe 1 month with thickness ( I can put a reverse, need to shut off the Porsche, then reverse and start again .. ) problems but using the car was solved ..
3rd time ( last week ) brOKe again ..
We thought have a bad alignment in the drive train .. dis misalignment make a lateral force over the push rod bearing, damaging it and off course brOKen the clutch disk..
opinions .. ?
All pars come from vertex brand new Satch
David Alonso De La Vega Tapage
Panama
944 Turbo
Old 12-30-2005, 08:37 AM
ae1969's Avatar
Send a message via ICQ to ae1969
This may sounds extremely dumb......but you do have a pilot bearing installed.........
I am trying to think how you can generate that much lateral force on that poor little disc.
Alex - PCA Polar Region - Boxster Muncher
86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD
www.edmontonhomelife.com
www.edmontonrealestate.ws
Old 12-30-2005, 09:40 AM
SoCal Driver's Avatar
Pilot bearing and/or drive shaft (torque tube) bearing.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 12-30-2005, 11:19 AM
Tapage's Avatar
My car had a crash maybe 1 year ago .. all drive train move backward maybe 2 inch. All measurements apears fine .. but I'm still thinking that I have a missalignment problem in the car that put some lateral force in the axle, or axle housing ..
right now I'm sad and very confused about that ..
Panama
944 Turbo
Old 12-30-2005, 01:24 PM
2 inches??? Yikes!!! Things are bent for sure.
Old 12-30-2005, 01:50 PM
Tapage's Avatar
Well .. I'm order new axles tube, my porsche master order the clutch again .. and the Porsche is for sale at this weekend ..
too much for me ..
Panama
944 Turbo
Old 01-03-2006, 06:24 AM
Rmills944's Avatar
Send a message via AIM to Rmills944 Send a message via Yahoo to Rmills944
Sounds like that one is a bit too bent up unless you are taking the drivetrain for another car.
Ryan
'84 944 moneysucker edition (SFR, Corbeaus, etc.)
'02 Jetta TDI 280Lb/Ft 145Hp @ wheels. RC2 PP357's
Old 01-03-2006, 06:37 AM
Tapage's Avatar
Right now we are in the process.
Changing axle housing and axle, bellhousing, again disc, push rod bearing, pilot bearing, the same thanny ( I hope that the tranny isn't the problem ... )
I thought this friday go out to do some test before selling it ..
Panama
944 Turbo
Old 01-04-2006, 05:04 AM
