Window switchs
Ok. I have an interesting problem w/ my window switches. Drivers side works fine but the passengers side if weird.
You can only lower the passengers side window with the botton on that side and to put it back up you have to press up on switch on both sides. It's anoying as hell.
If it has wheels or tit's it'll give out problems. Early 85 944 94 Katana 750 924 Parts Car |
Yea, but it's a dry heat
Had the same problem on mine. Had to pull the switch out and clean the contacts. Things tend to corrode after 15 years in my case. Switch works great now.
Ok. Well I replaced a couple of the switchs now that I think about it and I popped the cover off one and the little contacts popped out. I think I put them back right. Anyone know how they're supposed to be?
