Originally posted by todd84944
I'm here. The tranny out of the 924S does not not have the drive for the speedo for the late car. I have not done this, but I have been told that you can put the pick-up, and the pulse unit on a 924S tranny for a late car. The tranny in the 924S is the same tranny as in the 88 944 and the ROW cars, so I'm sure that this can probley be done.
I have converted two 924S trans for late inpulse sender. All you have to do is take out the threaded plug and take off the drivers side output shaft. Then put in the plastic drive gear and thread the impulse sender into the trans.Re install a new seal and the output shaft. It's that easy.
Old 02-25-2006, 09:47 PM
Send a message via Yahoo to asudds
WOW... great info everyone
Thanks....
Turns out the auto I was looking at was a friggin heap... but the 924S parts car may be much more... Everything works, including the air... some clean up inside and a little body touch up and I'll be good.
Aaron
Old 02-26-2006, 04:19 AM
