the inside click
My steering wheel makes a single 'click' sound when turning- it sounds like a plastic on plastic click- not anything from the front suspension. The source is IN the steering wheel itself- or at least in the mount / connections for the steering wheel.
I can make it click repeatedly by moving the steering wheel back and forth. It clicks once for each direction of turn- just past center.
Alignment clip? Bushings?
non-air bag, 1985.5
Someone suggested that ALL 944's do this but the sound is so subtle that most drivers never hear it. I doubt that as my 'click' is hard to miss and quite audible.
Old 04-14-2006, 06:47 AM
winter-hater club member
nynor's Avatar
my '83 had a copper contact in the steering column that would make a clicking noise.
"COOL PRIUS!" - Nobody Ever
Old 04-14-2006, 07:23 AM
The Chief's Avatar
Send a message via Yahoo to The Chief
Smile
Guys, I know I'm the new owner, and probably don't know much, but could this sound be from the little doohickie that cancels your turn signal once you begin to straighten the wheels after completing a turn?
1987 924S (Gretchen), Black on Black, phone dials, modifying for Autocross, daughter's car. (R.I.P - for now)
1978 928E, (Heidi), Minirva Blue, Op-Art & Cork Interior
1993 Mercedes 300DL Turbo (The Black Knight), Black on Black, wife's car.
Old 04-14-2006, 07:37 AM
nynor's Avatar
could be.
Old 04-14-2006, 08:17 AM
livewirevoodoo's Avatar
If it is the same click sound that I get then that is exactly what it is. Mine makes a double click tho, which makes sense because there are 2 metal posts which work in conjunction with the plastic turn-signal-cancel tab.
''87 944na 85k
C02 / M158 / M418 / M425 / M431 / M454 / M533 / M650 / M946
'94 Oldsmobile 88 Royale (winter beater)
Its not what you drive, its what drives you.
Old 04-14-2006, 09:01 AM
Could be all of the above, you wont know untill you remove the steering wheel. Its very easy to remove. Pop off the horn pad and remove the nut.
86 Red 944(sold)
85.5 Red 944(sold)
Old 04-14-2006, 10:32 AM
Kevin0323's Avatar
I'm thinking maybe the doohickey that locks the steering wheel when there isn't a key in the ignition?
1985.5 944NA
http://www.kevinswebsite.com/944/
Old 04-14-2006, 03:38 PM
