Crazy problem.
My car only starts when the gas tank is above 1/2 full or so. If started it will run fine regardless of tank level but if it is shut off it will only start if the tank is nearly full. The only fix seems to be to put in more gas. A gallon or two always does the trick. Any ideas?
83 944na
Old 06-27-2006, 10:26 AM
SoCal Driver's Avatar
Exorism.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 06-27-2006, 10:54 AM
Cars & Coffee Killer
legion's Avatar
New fuel pump?
5 liters of VVT fury now
-Chris
Old 06-27-2006, 11:16 AM
But it starts fine when it is full? And it runs well!
Any other ideas?
83 944na
Old 06-27-2006, 12:24 PM
Razorback1980's Avatar
Send a message via AIM to Razorback1980
Check the venting of the gas tank? My guess is that it's not the extra gas fixing the problem, it's the opening of the gas cap. Just a long shot guess though. Where does one find a car exorcist? Might be a good contact to have!
Tom
1990 944S2 Cabriolet
2002 Chevy Silverado 2500HD
2003 Maroon Ford F350 dually
Old 06-27-2006, 12:46 PM
Feelin' Solexy
Tishabet's Avatar
This seems like a pretty good possibility to me.
When you say it won't start, you mean the engine is turning over etc but it's not catching, right?
Grant
In the stable: 1938 Buick Special model 41, 1963 Solex 2200, 1973 Vespa Primavera 125, 1974 Vespa Rally 200, 1986 VW Vanagon Syncro Westfalia, 1989 VW Doka Tristar, 1995 Toyota Land Cruiser, 2011 Pursuit 315 OS, 2022 Tesla Y
Gone but not forgotten: 1973 VW Beetle, 1989 Porsche 944, 2008 R56 Mini Cooper S
Old 06-27-2006, 01:00 PM
Yes the engine is turning over but no catch. How do I check the venting? Is there supposed to be a vent in the gas cap or is their a seperate vent?
83 944na
Old 06-28-2006, 08:52 AM
I have noticed that when I remove the cap there is always a lot of pressure that comes out
83 944na
Old 06-28-2006, 08:53 AM
Eldorado's Avatar
actually i think that's the other way around... it's a negative pressure sucking air in..
Kyle
2008 Mini Cooper // '83 Porsche 944 // '01 Mazda Protege [sold] //
"Never break more than you fix!" - SoCal Driver
Old 06-28-2006, 09:23 AM
Any gas tank that does not vent a bit will colapse into itself like a crushed beer can.
You may have trash floating around in the tank that covers the intake at the bottom when the fuel level is lowered. Pumping fuel into the tank dislodges it or causes it to float a bit higher. Heard of someone having a golf ball in their tank that would do about the same thing.
Old 06-28-2006, 10:17 AM
Eldorado's Avatar
i agree with socal.. could be crud in the tank..
but this doesn't explain why it will stay running after that point...
what happens if you run the car until it's below the half way mark, and you turn the engine off and then immediately back on again.. will it start?
Kyle
Old 06-28-2006, 10:20 AM
Best thing is to put a fuel pressure gauge on the engine and see what the pressure is when it doesn't start. That will tell you whether you need to search down why the fuel pressure isn't there or not. If you have adequate fuel pressure and it still won't start, then look for what else is suppose to be there but isn't. If you don't have fuel pressure, start working your way back until you find the blockage. Takes four things to make an engine run..fuel, spark, timing and compression....trace down the one that is missing. Still want that exorcist contact though!
Tom
Old 06-28-2006, 12:39 PM
Granite 944's Avatar
Get it up on blocks/whatever............drain the tank, pull the tank screen out and look at it, replace/clean if/as needed (I'm betting on it). Change your fuel filter, and get on with life. typical maintenance issue. Do it anyway. You may even wanna pull out the sender unit, so you can look down into the bottom of the tank from above.........just to see the "crap" thats in there, possibly acting like a check valve.
If not it, come on back with your findings AFTER that.
1985/1 944 Granite Red (wife's car. Iceshark is lighting her way)
1983 944 Platinum (my daily)
1985/1 Guards Red (project)
Old 06-28-2006, 07:22 PM
jezza944's Avatar
While we are on this subject, is the cap vented? I have heaps of pressure (or suction) whenever I remove my filler cap. The smell of fuel vapour is really overpowering.
Dave Jezza
http://www.pelicanparts.com/gallery/jezza944
1984 944na Krystalgrun (Crystal Green)
Old 06-29-2006, 04:10 AM
Gas tanks are supposed to be venting through the charcoal filter. There is a vacuum switch and line set up to scavenge the vapors back into the intake.
Old 06-29-2006, 09:17 AM
Where is the tank screen located?
83 944na
Old 06-29-2006, 11:35 AM
earlr85944's Avatar
my moneys on the in tank screen and fuel filter also. and check the inlet screen on the fuel pump while your at it.
the filter unscrews from the tank where the rubber fuel line attaches from it to the fuel pump.
83 944....bye bye
85.5 euro spec 944, 5sp (she's gone....
74 914...hasta LA Vista baby
87 924s....don't let the door hit ya
68 912.......see ya!
Old 06-29-2006, 11:52 AM
