Help
anyone have ideas on how to take the nut off the front strut assembly? the one with the allen bolt in the middle? thanks
84' 944 |
Will work for parts
Go to a parts store and buy an oxegen sensor removal tool. It allows you to get an allen or socket in the middle to hold the strut shaft. Make sure you have a spring compressor on the spring if you have stock springs first.
'88 944 240,100 miles -race car '05 Boxster 110,000 - Daily Driver '74 911 Targa - long term project |
Impact Wrench.
Good luck, George Beuselinck |
If you are planning on doing the inserts (shocks) I would take the entire strut out first. The two large bolts at the spindle and the four nuts/studs at the top. Once the strut is out you can get the spring compressors on it and have at the top nut.
Hugh - So Cal 83 944 Driver Person NOT a 'real' Porsche -- Its Better!!!! When was the last time you changed your timing and balance belts and/or cam chain and tensioner? New Users please add your car's year and model to your signature line! Never break more than you fix! |
