liljon's924S's Avatar
Sway Bar Upgrade
I just purchased a 26.8mm(27mm) sway bar for the 924S and it came with the two metal peices to mount it to the body. My question is what will I need to buy to install it other than new, bigger inner bushings. Do I need new outer bushings, and if so, what size.
Thanks!
"I couldn't find the sports car of my dreams, so I built it myself."
-Dr. Ferdinand Porsche
'87 924S Guards Red, 944 turbo bars, 220lb. springs, Restoration Project even though its and original, 72,000 mile car
'93 325is Red, aftermarket rims, pirelli tires, 95,000 miles
Old 08-27-2006, 03:05 PM
Here is a pic
Old 08-27-2006, 03:07 PM
Re: Sway Bar Upgrade
Thanks!
It should just bolt right up in place of the other front one. You did not mention a rear bar, if you don't have the rear bar to go with the 27mm front one don't even bother, as the 27mm front bar should be installed with either the 16mm or 18mm rear bar.
Mark
'86 944NA
'10 VW Golf 2.5 5sp
'99 BMW 540i Sport Wagon
Old 08-27-2006, 07:21 PM
That Guy
Techno Duck's Avatar
Unless you at some point changed your control arms to the alloy type, i dont think its possible to properly mount that sway bar onto your car. The steel control arms used an entirely different endlink.
It might be possible to bore out the rubber bushings on your end links but it wont be a perfect fit.
Jon
1988 Granite Green 911 3.4L
2005 Arctic Silver 996 GT3
Old 08-27-2006, 07:22 PM
Just put the swaybar on the car today and it bolted up fine. I did have to bore out the outer bushings but that was easy. I didn't get to test it because the tropical storm has arrived. I'm also thinking about instaling a rear sway bar on my car since it doesn't have one. Is this possible? If so what parts are needed? What rear bar size will work the best with the 26.8/27mm front bar?
Old 09-01-2006, 11:48 AM
That Guy
Your car is going to understeer pretty heavily with a 26.8mm bar upfront and nothing in the rear! Get atleast a 18mm or the more expensive 19mm rear bar.
There is a bit of hardware you will need however..
Jon
Old 09-01-2006, 02:31 PM
What hardware is needed other than droplinks? Also where can you buy cheaper droplinks, they are $154 each on here!
Old 09-01-2006, 02:53 PM
Call a Porsche dismantler (Junk Yard).
Mark
'86 944NA
'10 VW Golf 2.5 5sp
Old 09-01-2006, 03:43 PM
arbita1's Avatar
check out DC auto.
Matt.
83 911SC
85.5 944 NA - Sold
Old 09-01-2006, 03:50 PM
Well I just got on paragon products and they have a rear sway bar adapter kit for $90. The kit fits 924S, 944 and says, "Kit allows addition of rear sway bar to those cars delivered without." Will this kit give me everything I need to add a rear sway bar?
http://www.*****************.com/product_p/sb6910.htm
Old 09-01-2006, 03:51 PM
Ok, I think I know what to do- order the KLA droplink kit($70) and the rear sway bar adapter kit($90) from Paragon, then get a rear bar. These two kits look like they provide all I need to install the rear bar. Am I right?
Old 09-01-2006, 04:18 PM
Stop
See if you have the shackle mount points on your torsion tube. If you do, you don't need an adapter. On early 924's if the car was delivered without a rear bar there were no mounts. I believe all 944's and possibly the 924s have the mounting points even if the car was delivered without a bar.
Also make sure your eccentric bolts have the stud for the droplink. Same issue here as I spoke of above
If you have the mounting points you need the droplinks, shackles, and a bar with the bushings. Try and get all this from ebay or someone parting a car as a package deal. You will save $$$
Regards
Graham
Early 85 944
Factory Cold Air Intake
Radial Tires
Old 09-01-2006, 05:09 PM
I do have these main sway bar attach points.
But I still cant figure out where this is
Old 09-02-2006, 05:12 AM
Right The bolt above the arrow is the stud on the eccentric that I was referring to. The droplink in the picture will bolt to the trailing arm using that stud. The other end bolts to the swaybar. So slide underneath and see if you can see the stud. If so you are way ahead of the game.
Graham
Early 85 944
Radial Tires
Old 09-02-2006, 08:45 AM
Ok, I got under the car and there is no stud on the end of that bolt. Is that a problem and I wonder if that would come with the kit from paragon products?
Oh,and another thing, My dad said that my car doesn't need it. He said if it would have needed it, the factory would have put it on. Is this true
Old 09-02-2006, 09:07 AM
That Guy
There is no stud on it because its a different eccentric bolt. You need the double sided bolt.
Your car dosent have it probably because of the cost it would have taken to put a sway bar on every 924S from the factory. It did come with a rear bar when the 924S was ordered with the factory sport suspension option. Think about it. Your car came with a 21.5mm FRONT sway bar from the factory and no rear bar rear. Your car in stock form probably understeered heavily like this. You now have a 27.8mm bar on the front and STILL no rear bar. Its obvious whats going to happen with this setup!
On a side note i have a 18mm rear sway bar for sale.. it does not have any hardware or bushings though. Asking $40 + about $20 shipping.
Jon
Old 09-02-2006, 09:27 AM
You need to replace the two eccentric nuts with the ones that have the studs. They are @ $20.00 each. I don't know what the Pelican kit has, call them if you can't figure it out by the listing.
Adding that large front bar really imbalances the handling of the car. Porsche NEVER sold it like that.......
Regards
Graham
Early 85 944
Radial Tires
Old 09-02-2006, 04:59 PM
