Adjust timing?
If the timing belt was of by one or two teeth would the car run lousy, like it was misfiring or running hard? Normally you could turn the distributor and adjust the timing but since these cars don't have that how do you adjust the timing?
Reason asked is I just replace the timing and balance belts on mine and it runs lousy. Ive got the belt placed correctly, unless the timing belt is off by a tooth or so.
86 Ford Bronco
87 Porsche 924S
98 BMW 318ti
01 VW Turbo Bug
Old 09-11-2006, 08:40 AM
fast924S's Avatar
Send a message via AIM to fast924S
Timing can not be adjusted its controled by the DME. If you are off a tooth or 2 then that could be your problem. Be careful too far an you can smash a valve
1986 951, Stock for now.
]87 924S Gaurds red- SOLD after 11 years of ownership
Old 09-11-2006, 02:21 PM
