Control arm bushing question
I know to put new front control arm bushings in you need a press, would it be possible to use a vice or can you not get enough pressure? And how hard is it to remove the old bushings?
-1988 Black 944 w/ yellow koni's, coilovers with 250lb springs, adjustable camber plates, strut tower brace, weltmeister front and rear sway bars, 968 caster blocks and 5 pt harnesses www.apartabove.com |
Unfortunatly the OEM rubber bushings can be quite challenging to get in and out. I've used a vice, and various deep well sockets to push them out, and act as a backstop for the A-arm. Lighter fluid works well as a lubricant, and will evaporate fairly quickly. Removing them envolved cutting off the rubber shoulder on one side, and punching it out the other.
I have the Delrin two-piece bushing, much easier to install, (but quite a bit more expensive) but it is a race car. good luck JM
Thanks for the help. That's exactly what I wanted to hear.
Weltmeister makes replacement bushings for this that are very easy to install.
However there is some debate as to how good they are. I have them and autocross and have had no problems...Yet!
Matt. 83 911SC 85.5 944 NA - Sold |
I rebuild my front end about 1 year ago and used the weltmeister bushings, no problems so far. I rebuilt the ball joints, strut inserts, tie rod ends, sway bar bushings.
Rick 99 996C4 06 525XI 87 944S - Sold 77 924 - Sold |
Let's go shooting.
Putting in the new bushes is a piece of pi$$. Thoughly clean the insides of the bush retainers to help ease it in. Place the bush in position and then get a long bolt threaded down the majority of its length (or a screw) and put it through the steel centre of the bush. Place a socket on the other end - just big enough to allow the end of the bush to enter it. Put a nut on the end of the bolt / screw. Put the head in a vice and tighten the nut with a spanner against the back of the socket until it draws the bush into the control arm retainer. Doddle. Takes a few minutes per bush.
1983 944 Lux (manual) 2.5 litre 8 valve na and no pas 1991 944 (automatic) 2.7 litre 16 valve na and pas "I have only five words for you: From my cold, dead hands." Last edited by Dark Skies; 09-24-2006 at 05:14 AM.. |
