How do you replace the bumper shock absorber
I noticed that the driver side of the bumper is pushed in and won't pull out. Can anyone tell me how the bumper shock absorber is replaced. I can't even see the thing when I look under the car.
Thanks......................Vern
Old 01-15-2007, 11:35 AM
cold starter
JustinL's Avatar
Front or rear? 944 or 951/S2?
88 Turbo S Silver rose: Megasquirted fuel, assorted suspension upgrades, etc.
89 944 S2 with 968 engine: Race car
87 944: Chump car build in progress
Old 01-15-2007, 01:36 PM
It's the front driver side - thanks.
Old 01-15-2007, 01:51 PM
cold starter
JustinL's Avatar
I'll assume it's a n/a 944 with the big steel bumper. It's held on by the two big bolts that are accessed from underneath behind the bumperettes. Remove those bolts and disconnect the electrics. You should have a pretty good view of the two bolts holding each shock to the frame.
Once you have them out, you can replace the broken one or drill a hole in them to compress them down for the snub nose look. That's a different discussion though
Justin
Old 01-15-2007, 03:33 PM
Thanks Justin.
Now if it weren't 30 degrees outside, I'd go fix it right now. What's with this cold weather in California? I don't like it.
Old 01-15-2007, 05:32 PM
SoCal Driver's Avatar
Bumper is aluminum.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 01-15-2007, 06:21 PM
Send a message via AIM to hpaulb
Backed into my Porsche last year. Pushed the shock right in. Took it out and just gave it one wack and it pooped out the the perfect position.
87 924S 107k (miles) yellow
1969 Firebird Coupe (Full frame off restoration.)
98 BMW 740i
2020 Subaru Outback and 2019 Crostrek.
Old 01-18-2007, 11:35 AM
Thanks for the tip. I ended up getting a bumper shock at the wrecking yard. The car is in the shop getting a new timing belt and so I won't be able to work on this until next week.
Maybe mine will just snap back into place but if it dosen't, I got the replacement ready to go.
Old 01-18-2007, 11:51 AM
Gremlin85's Avatar
Send a message via AIM to Gremlin85 Send a message via Yahoo to Gremlin85
Question
Justin [/B][/QUOTE]
Could you direct me to a post or have any pics as to how this is done exactly... I saw one (1) pic of it and I fell in love with the look. Please, anyone, any direction is much obliged.
Thanks!
1987 944 N/A Gray on Burgandy, Manual. Koni adjustables, lowerd. 16" two-piece Five spoke French rims. BROKEN.
2004 Pontiac GTO. 40th Anniversary Pulse Red 6-Speed with Pacesetter Long Tube Headers, catless mids, drag springs, DBA Slotted Rotors with C5 Hawk Pads. Tuned By Staging Lane Performance.
Old 01-18-2007, 12:29 PM
cold starter
JustinL's Avatar
http://forums.rennlist.com/rennforums/showthread.php?t=118623&highlight=snub+nose
From the other list
There is debate as to the crashworthiness of this mod, so no more parking by feel!
Old 01-19-2007, 09:03 AM
That Guy
Techno Duck's Avatar
There is no debate on how the snub nose look will change the outcome of what could have been a relativley minor 'bump'. You compress a shock that is meant to be a buffer and by doing that you lose any chance of getting away with no damage with a relativley low speed bump (im talking less than 5mph). On the plus side you have an extra inch to stop before your bumper hits the car infront of you .
Compressed shocks look great, but dont take the bumper pads off, it looks terrible.
This is my '87 with the pushed in shocks..
Jon
1988 Granite Green 911 3.4L
2005 Arctic Silver 996 GT3
Old 01-19-2007, 09:41 AM
Gremlin85's Avatar
I'm gonna give it a try when I get a chance. Other things come first. If I don't like it does anyone have extra used CHEAP bumper shocks?
Old 01-19-2007, 09:52 AM
Gremlin85's Avatar
oh, by the way... my bumper has the washer sprayers for the lights... are those gonna have to go or can I adjust them to still work?
Old 01-19-2007, 10:34 AM
That Guy
Washer nozzles shouldnt be a problem, probably will have to aim them a bit higher.
Jon
Old 01-19-2007, 10:46 AM
I was able to pull the bumper out with a come-along hooked to the bumper from underneath and tied off to a friendly maple tree. It popped right out and into original position. Neat. Didn't have to take anything apart.
Jon
87 924S
82 924-Gone.
80 924 parts car-Gone.
Old 01-21-2007, 03:43 PM
