martin944's Avatar
Question on 944S spark plug wires
I'm about to remove the valve/cam cover to replace the gasket. Do you just pull off the plug boots from the plugs? it looks like you need to loosen the cover prior to pulling the plug wires. Pls clarify.
Thanks!
Old 02-13-2007, 05:50 AM
Razorback1980's Avatar
Send a message via AIM to Razorback1980
I don't own an S but I don't think so. I think that is just the way the caps are built. Plug wires should come off first.
Tom
1990 944S2 Cabriolet
2002 Chevy Silverado 2500HD
2003 Maroon Ford F350 dually
Old 02-13-2007, 10:41 AM
martin944's Avatar
Thank you sir!, the caps do look like they are embedded into the cover.
Old 02-13-2007, 11:16 AM
SoCal Driver's Avatar
Check out the cross over chain and plastic pressure pad too. Bet there is a big groove in the plastic.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 02-13-2007, 11:26 AM
gtroth's Avatar
Yup, pull them right off first. I use some Robogrip pliers with the protective rubber covers on the jaws and gently wiggle and pull.
If you're replacing the gasket, replace all the seals (4 plug seals and 13 bolt grommets). And search around on "chain tensioner" to see what else you should do and look out for (careful with those bolts - they can break...).
1995 993C4 guards red
1988 944S alpine white
Old 02-13-2007, 06:25 PM
