Temperature Gauge - What's normal
My 944 is new to me as I have only had it a month. It only has 18k miles and had been in storage for 7 years.
I had a shop replace the cam belts, rollers, and water-pump before I ever started it up. My temperature seems to be at the high end. It never goes past the upper "white" mark but it is frequently right on that line. It moves from dead center to the top white line. Is this normal? I'm used to my BMW where the temperature gauge stays in the middle and never moves. The shop put in a new genuine water-pump and thermostat but I wondering if I should replace the thermostat with a cooler one. Can you guys let me know what your cars usually run at. My car is a 1988 N/A car, and runs very well except that I need to replace a few vacuum lines to get it perfect. Thanks in advance........................Vern |
a needle width above the middle line all the time. hiway speeds, idling, traffic, even with a/c on.
87 951, K27/6, Almond Beige, 17" Turbotwist 87 944S, alpine white, 5sp died a violent death 84 944, silver/brown, auto, gone but not forgotten "may the force be with you" |
That sounds about normal to me. Now I wonder why mine fluctuates.
My 1983 does the same thing, if I am running down the road it will stay in the middle, if I am setting still or in stop and go traffic it will go to the white, the fans will kick in and the temp will go back down to about middle and the cycle starts all over again. I have asked about this on the forum and seems like this is the normal.
Brian 1983 Porsche 944 Silver with Brown Interior. 2005 Honda Goldwing 2000 Husaberg 400 2001 Sherco 2.9 1968 Honda CT-90 2001 Arctic Cat 500 Auto 1998 Toyota PU 2001 Toyota Highlander AWD 1991 Tiffin Motorcoach 2006 Suzuki 450 Super Motar |
where as mine stays a needle's width below the first line..
odd..
Kyle 2008 Mini Cooper // '83 Porsche 944 // '01 Mazda Protege [sold] // "Never break more than you fix!" - SoCal Driver |
I have a 87 944S, mine stays a little above the the first line on normal driving , but somtime goes upt to the 2nd line in traffic, then back down again when the fans kick in.
My 88 goes just above the first line. It seems that yours may be going to high.
Neal 1988_944na India Red/Blk Int. |
Graduated User
I wonder what a new tempreature sender would do? I'll find out, I just bought one from our host.
Randy 1977 Scirocco Rebuilt 1.7L Stock Grey (Totaled) 1979 Scirocco Built 2.0L Stroaker Blue (Pilfered) 1979 Scirocco Built 1.8L Rust Bucket Tan (See ‘ya) 1982 Scirocco Rebuilt 1.7L Garage Kept Gold Daily Driver 1987 944 NA Rebuilding 2.5L One Female Owner Grey Weekender Cruising to a conkeytonk in my Scirocco on steroids |
I think that where the temp. guage sits is dependent on the voltage from the alternator... mine *used* to sit about 1/4 of the way through the "normal" range except when it heated up, it would get almost to the white and then the fans would kick in. I've since installed a Transpo regulator and my voltage is now close to 14 on the gauge (14.1 at the alternator) and it sits just of the bottom white line and will go up to about halfway until the fans kick in.
Unfortunately about the same time I did all this I also had the thermostat, thermoswitch, and radiator replaced (the car was running the fans too much and sometimes they couldn't keep up) so I can't say if the new thermostat opens at a different temp. than the old one did. Likewise it is possible that the new thermoswitch is kicking the fans in sooner. nate
1988 944... and a bunch of other cars
http://www.clarks-garage.com/shop-manual/elect-19.htm#coolant
go here all the info you need by this yours is working perfectly i had the same question earlier and looked it up
1986 944 n/a hard top, black on burgundy |
Thanks 61I60,
I use clarks garage all the time but I have not seen this page. This will help me a lot. My car has the newer gauge. I didn't realize the early cars were different - which explains the variety of answers (all heplful). Thanks again...................Vern |
mine will initially travel up to the 3 bar first thing till warmed up
then during operation ,it stays a just above 1 bar in traffic it will travel to middle 2 bar i figure as log as it stays below 3 bar we are all good i have the later dash as well
Ornery Bastard
On my '86 951 the temperature guage sits just above the 80 Centigrade mark (first white line) with very little fluctuation at all, even in traffic and idling.
--------- Silver 1998 Volvo S70 T5 <- Daily (Anja) Guards Red 1986 951 <- Seattle car (Gretchen) White 1976 914 2.0 F.I. <- Prodigal car, traded away then brought back again (Lorelei) |
