possible 944 fire
Decided i would drive the 944 this morning
it had rained all day yesterday if this helps started car warmed up drove to gas station about 1 block away had defroster on & head lights , the normal stuff got out of the car when i came back the interior smelled awful rotten eggs & car died noticed oil px was low got car to restart drove it back to house and it died again i disconnected the battery encase of elect short ??? how are the harnesses in the 944 is it a sectional harness meaning i can just replace the under dash pieces 2nd ever hear of this happening where should i start looking for the cause im leaning to the interior since you can only smell it inside and not outside
1986 944 n/a hard top, black on burgundy |
winter-hater club member
the rotten egg smell is your battery. your charging system is faulty.
2000 Corvette - ????, 2007 Buell XB9R - Astrid, 1996 Discovery - Piglet, 2000 Forester "COOL PRIUS!" - Nobody Ever |
cool ill start there
that would explain why the car dies
The front end is a detachable harness. Goes through the fire wall to three conectors. The biggest is the computer and a 3 connector and a 2 connector. Checkk all your grounds. There everywere. Should be diagram on this site. First car I've seen like this and a lot of people have problems. Pull them of and clean them.
87 924S 107k (miles) yellow 1969 Firebird Coupe (Full frame off restoration.) 98 BMW 740i 2020 Subaru Outback and 2019 Crostrek. |
cool i just checked the chargeing sys
13.15 v off and 13.86v running so its cargeing so ill start with the grounds next
Rotten egg smell from battery means it is over-charging. Make sure that your regualtor is regulating and not over-charging your batttery. Rotten egg smell also caan come from catalytic convertor. But its prob your battery being over-charged.
Dave 1984 944 N/A Black (Daily Driver.) New Users please add your car's year and model to your signature line! |
the cat is 2 weeks old so i doubt it would be that
and at 13.86 v running i doubt its over charging butt it might have been over charging earlier and not now I'm starting to scratch my head on this one . theres a bunch of freaking grounds to clean and some really suck to get at and its not smelling up the joint anymore so what ever it was , it has stopped for now. butt ill keep looking for burnt & sulfur /egg smelly items
I hate chasing funky smells in a car. It cn take forever. Good luck to you.
There are grounds all over, some are near the front under the nose panel area by the left front fender. About 8 of them all bundled on one bolt. They are hard to get to but if you are going to clean ground might as well clean them all. It's worth it down the road..
M |
OK, I respect German Design, but.... WHAT THE HELL WAS PORSCHE THINKING? 8 Ground wires to one ground point? I always was told never to ground on top of another ground... I understand the whole chassis is a ground but I was told grounding on top of another ground directly can cause weird electrical problems, especially in audio/video systems.
1987 944 N/A Gray on Burgandy, Manual. Koni adjustables, lowerd. 16" two-piece Five spoke French rims. BROKEN. 2004 Pontiac GTO. 40th Anniversary Pulse Red 6-Speed with Pacesetter Long Tube Headers, catless mids, drag springs, DBA Slotted Rotors with C5 Hawk Pads. Tuned By Staging Lane Performance. |
The car I was working on at the time I noticed that ground point DID have an extremely rigged wiring harness, but I am pretty sure it had several grounds all bolted to the chazzy at one point and I am pretty sure all the cars are like that..
M |
So, in theory, wouldn't it be better (healthier) for the electrical system to seperate those grounds to other locations and even expand on the ground system? It could help with electrical problems that, in essence, start fires (with the exception of the notorious fuel line).
