Thumbs down Headlight Issues
I recently removed my torn Headlight motor/relay boot. I failed to disconnect the battery.(Probaly the begining of my problem) I disconnected the relay and wire connection. I removed the boot. Reconnected the wires and relay... Now my lights do function properly, but will not go down. I tested the motor, it cycles properly. I replaced the relay with a new one. Still the same outcome. The lights will go down manualy, this just isn't a cool look. Popping the hood to lower my lights. Any ideas?
Old 04-15-2007, 07:32 PM
Eldorado's Avatar
i had to jiggle the relay, make sure it was in just right....
Kyle
2008 Mini Cooper // '83 Porsche 944 // '01 Mazda Protege [sold] //
"Never break more than you fix!" - SoCal Driver
Old 04-15-2007, 10:52 PM
Might also be your switch, if you have a spare swap that in to rule it out.
82 931 Platinum<--GTS in progress
Old 04-16-2007, 03:36 AM
Those didn't seem to help... any other ideas???
Old 04-16-2007, 06:47 PM
Eldorado's Avatar
with the battery connected and lights closed, when you start to raise the lights manually, do they cycle up and then close themselves automatically?
if you test this, be careful... lots of quick moving parts around..
and count your fingers when you're done.
Kyle
Old 04-16-2007, 07:10 PM
SoCal Driver's Avatar
Electrical issues are a hands on fix. Pelican has the early 944 wiring diagrams and the headlight circuit is pretty much the same for the later 944's.
http://www.pelicanparts.com/944/electrical/944_electrical_diagrams.htm
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Old 04-16-2007, 08:45 PM
Razorback1980's Avatar
Send a message via AIM to Razorback1980
I agree with Kyle...watch your fingers.
Tom
1990 944S2 Cabriolet
2002 Chevy Silverado 2500HD
2003 Maroon Ford F350 dually
Old 04-16-2007, 09:12 PM
Kyle
'83 Porsche 944
They do not cycle up and then close automatically... Should they?
Old 04-17-2007, 01:43 PM
erics944's Avatar
Sorry if hijacking this thread, but this is the exact symptom I have. My lights don't go up, but lights come on. Once I start turning the lights up manually(with the lights on) they pop up and go back down(only the one cycle). Any ideas what could be the problem. I have replaced the headlight motor relay and the switch in the dash.
'86 944 na; '99 Eddie Bauer Explorer; '03 Windstar
Old 04-18-2007, 04:08 PM
Eldorado's Avatar
yes, avachon, they should cycle as I said..
Eric, if they cycle by spinning it manually, and you've changed the relay and the switch.. I'd check the switch again, then the wires behind the switch, as well as the wires to the headlight motor..
something else you can try.. flip the switch in the on position, then give the lights/motor/actuator arm a little tap... it might be binding on something.
Kyle
Old 04-18-2007, 04:57 PM
The Chief's Avatar
Send a message via Yahoo to The Chief
When something similar happened to me (lights came on, did not "pop" up, but cycled when manipulated) it boiled down to the linkage hanging up on the hood cable release on the left side of the engine compartment. My daughter thought she had broken the car (it was the first time I let her drive it); just got a cable tie and moved the release cable out of the way.
Hope it is as simple....
1987 924S (Gretchen), Black on Black, phone dials, modifying for Autocross, daughter's car. (R.I.P - for now)
1978 928E, (Heidi), Minirva Blue, Op-Art & Cork Interior
1993 Mercedes 300DL Turbo (The Black Knight), Black on Black, wife's car.
Old 04-18-2007, 05:46 PM
