question on front emblem replacement
My front Porsche emblem has seen better days. I went to the how to at http://clarks-garage.com/shop-manual/body-09.htm seems pretty easy thing to do.
I follow this procedure to remove the nose panel, but I can't see the machine screw located under the front lip of the nose panel in each headlight bucket area that is talked about. My headlight buckets have a rubber seal of sorts that covers the retaining nuts at the bottom of the headlight bucket. This seal is blocking the view of machine screw under the front lip of the nose panel. Does this seal just pull out? Seems like it should, but I don't want to rip it.
I will post pictures tomorrow of what I'm talking about.
Garold Shaffer
1973 914 2.7 /4 Flared Beast - SOLD
74 2.0 Daily Driver
74 LE Bumble Bee Project car
Old 04-17-2007, 09:02 PM
Eldorado's Avatar
did you see this?
"Remove the machine screw under the lip of the nose panel using a 10mm socket, universal, 2 inch extension, and ratchet. A 1/4" Drive 10mm socket is small enough to fit under the lip of the nose panel."
Kyle
2008 Mini Cooper // '83 Porsche 944 // '01 Mazda Protege [sold] //
"Never break more than you fix!" - SoCal Driver
Old 04-17-2007, 10:14 PM
Yes, and that is the problem. Ihave a big rubber seal that runs along the bottom of my headlight bucket. It is in the way. My questions is how do you remove the seal?
Garold Shaffer
74 2.0 Daily Driver
Old 04-18-2007, 05:06 AM
scottcip1562's Avatar
On my 85.5 the emblem was just pressed into plastic grommets. All I did was pry very carefully around the edge and came right off. You can get your hand under emblem and feel to see if there are speed nuts or just the pins holding it in place
79SC, Wevo Shifter, SSI, Koni's, MK Muffler
85 944 Stock
Past Porsche's
87 944
87 928S4, I was young and dumb
99 Boxster
70 911T
Old 04-18-2007, 06:06 AM
Eldorado's Avatar
my 83 just pulled off too.. i'm not sure what year they started screwing them down..
Kyle
Old 04-18-2007, 09:01 AM
Eric 951's Avatar
The rubber just lifts out of the way--pull it up(you don't have to remove it) and you can access the screws.
Eric
83 911SC/83 944
bunch of Honda 750s
Old 04-18-2007, 09:18 AM
mr. dude's Avatar
Yep, just what Eric said. The rubber peices can either be pulled out or just lifted enough to get to the screws.
2006 Porsche Cayman S
2006 Lotus Exige (Sold)
1986 Porsche 944 (Sold)
1981 Porsche 931 (Wrecked)
1987 Porsche 944 (Sold)
Old 04-18-2007, 12:01 PM
I just replaced mine last week on an '86. The two post simply set into two rubber grommets. No sign of speed bolts. The rubber gasket seamed a little small to fit around the emblem. I gently stretched it, enlarging it enough to fit. The new ones looks ten times better!
Stephen Fraser
Poland Spring, ME
1986 Guards Red 944NA
Old 04-18-2007, 06:47 PM
