'84 died on the road, restart - died, then no restart
My '84 died right as I was rolling through an intersection, coasted to the side of the road - restarted. I'd say it ran for about two seconds then died. Then, no restart - all lights, gauges, radio, dead - no cranking.
Enter helper - hooks up jump leads, so I can at least roll up the windows - turn the key, start right up. I get out, unhook jump leads, by the time I get back to the driver's door, it dies. Repeat that twenty minutes later (maybe about 20-30 sec running, then dies). Once more, jump it - this time I rip off the jump leads, hop in, and speed away at about 60mph in town and make it home.
I'm pretty sure it's not an electrical problem, since it did die in mid-run. Any ideas what is to blame?
'84 Porsche 944
Old 05-26-2007, 07:25 PM
winter-hater club member
nynor's Avatar
sounds electrical to me. alternator?
"COOL PRIUS!" - Nobody Ever
Old 05-26-2007, 07:32 PM
Sounds like an alternator problem. Once voltage levels drop enough, the car cannot run at all. Jump will get the car going again but only until charge is depleted in battery. If you charge up the battery, start engine and pull the ground cable off the battery. If the engine dies the alternator is to blame.
Mark
'83 Porsche 944 NA
'90 Porsche 944 S2
Old 05-26-2007, 07:33 PM
OK, I'm showing 12.06 VDC at the batt. Running, though, I only get 13.6 (perhaps alternator, perhaps otherwise, I'll have to check the drop over the alternator later/tomorrow). I'm also pulling about 90mA at rest (too much, right?). So, I checked my fuses - turned the key, hit the headlights - dead, lights off power gone. I had to wait a few minutes before I could try again and it worked. Then I noticed something else a bit disturbing. Both side markers on the passenger side are out (despite an intact fuse), as well as the right side reversing (white) light. Also, the passenger side window switch doesn't work (the switch is good), though that window can be controlled from the driver door. Might I have a short somewhere in there that is draining the battery? (In addition to another potential alternator problem?)
'84 Porsche 944
Old 05-26-2007, 08:40 PM
Eldorado's Avatar
cheap stuff first - take your battery for a free test at an autoparts store. after that, if you have to, dig out and take the alternator.
as for the lights, try changing the bulbs... if they blow again, you've got a problem..
have you done anything to the lighting/electircal system lately? anything at all? even something as little as change some bulbs..
Kyle
2008 Mini Cooper // '83 Porsche 944 // '01 Mazda Protege [sold] //
"Never break more than you fix!" - SoCal Driver
Old 05-26-2007, 09:10 PM
Politically Incorrect
onZedge's Avatar
Never disconnect the battery, with the engine running, on an ECU equipped car!! Alternator may output unregulated voltage, and that will fry the DME.
Edek
'87 924S
'91 535i
Old 05-26-2007, 09:33 PM
I was checking out a problem with my current draw - removed and replaced a few relays to see if I couldn't find the root of that problem. (I didn't.)
I really don't think it's a coincidence that the entire right side of the car is electrically crippled and the rest works perfectly. Ashtray light works fine - glove box light doesn't. Clock doesn't work, the two warning lights for seatbelts and handbrake don't work, as I've mentioned - no side markers, no right side reversing light.
(Also, I don't know how to get at those bulbs to check them.
'84 Porsche 944
Old 05-26-2007, 09:36 PM
Update: The side marker lights are operable, I switched them to the other side without a problem.
I started pulling some fuses, from a baseline draw of .160mA. At fuse 7, that drops to .060mA. With fuse 7 in and the driver's door open, I draw about .8mA. With the passenger door open, I still draw the same baseline .160mA. This leads me to believe my short is somewhere before the passenger door switch... can anyone confirm?
'84 Porsche 944
Old 05-28-2007, 01:55 PM
It's your car's computer brain. Under the passanger's footwell rap the computer case and then try and start. If it does - resolder the larger connections in the computer...wanna bet this is it?
Joel
87-944 Automatic 300,000 mi
83-944 5 speed 550,000 mi
Old 05-28-2007, 11:09 PM
SoCal Driver's Avatar
I'll take the bet! The early 944's have the DME under the steering column right about the drivers knees!!!
Can still have loose solder connections.
I would check out the battery for a dead cell and clean the heck out of all it's electrical connections and the grounds between it, the chassis and the engine.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Old 05-29-2007, 09:23 AM
