Smile R-134a Retrofit Port adaptors
I was shoping at my local wally world and i came across a kit that had Fittings to adapt all cars and all years To convert r-12 to R-134a. I purchased the kit and the high side port adaptor is kool but the bottom on a/c has some clearence issue but i think a smaller a/c-alternator belt may take care of that. FYI i have not fully threaded or installed the adaptors. So anyone outhere have expierence with a similar kit and conversion and can offer any advice?
Jaime O.
Thank god I crashed or i would never have owned a porsche
83 944 daily driver (clutch and tt time)
85 325e BMW T-boned R.I.P.
Old 06-20-2007, 10:06 PM
Eldorado's Avatar
yea.
dont expect to just put the fittings on, fill with 134, and go. much *should* be done to the a/c system before filling with 134.
Kyle
2008 Mini Cooper // '83 Porsche 944 // '01 Mazda Protege [sold] //
"Never break more than you fix!" - SoCal Driver
Old 06-20-2007, 10:27 PM
Drainign the system and posible a new dryer are probly going to be done. By the way Eldorado since you like the Duracool substitute so much. does it adapt to the old fittings the vehicle has?
Jaime O.
Old 06-20-2007, 10:42 PM
Eldorado's Avatar
Duracool = canadian - w00t! =P
it does adapt, as far as I know. absolutely no modification needs to be done to your system in order to use it. as long as you have no leaks, and adequate oil.. you're good to go.
Kyle
Old 06-21-2007, 01:01 AM
Greasy Member
many944s's Avatar
+1
Both Duracool and Freeze 12 can be added to an existing R-12 system with no changes. If your system is "opened" for any reason (changing compressor, dryer, o-rings) you should pump it down to a vacuum before adding your refrigerant. If the system still has pressure, you can simply add the new refrig.
Why to evacuate system:
Pumping the system down to vacuum for half an hour or so pulls the majority of the "condensible" materials from the system (mostly water vapor from air). If there is air or moisture in the lines, the A/C wont function as well.
I would advise staying away from the R-134a conversion kits. For the system to function well over the lifetime of the car, you should drain ALL of the original Mineral oil from the compressor, change the seals and o-rings, swap out the dryer, and use a good clean PAG oil charge, it costs a little more than the $39.95 box on the shelf that says "R-134 conversion kit, everything you need"
Hope it helps!
-Nick
Owner: Bennington Motorsports www.benms.com
Sponsor for Midwest Region 944-SPEC racing series
-When was your timing belt changed or tensioned??
-Yes, I'm the crazy man that will loan out my 9201. Just PM me, I will add you to the list and get it out ASAP.
Old 06-21-2007, 06:00 AM
Yes indeed it does. I need a 90o fitting for the 134 upgrade. That kinda slowed me down not to want to mod it. And there is a duracool manufacture in the U.S. eldorado :P. As far as the leak I think i may have some b.c the radiator for the A/C has like a oily Buildup that i have to degreese. But that maybe from my oil leak on the block. But it maybe the a/c b/c i dont think oil shoots out foward when im driving. Well now that i think about it. it's probly leaking cuz i charged it last season with r-12 and this season.. Very much not blowing cold.. cool to say the least.
NAPA has it you say Eldorado? i'll have to check it out
Jaime O.
Old 06-21-2007, 03:53 PM
Ok napa didnt have duracool but they had freez 12. so the next question is.. Low side service port is on the A/C pump and High side service port is at the Top by the Headlamp Correct?
Jaime O.
Old 06-21-2007, 05:11 PM
Just thinking out loud
mattdavis11's Avatar
Yes, and you have a bad condensor, or so it sounds.
91 FJ80
84 Ram Charger (now gone)
Old 06-21-2007, 07:15 PM
Eldorado's Avatar
fix the leaks, or you're wasting your money.
Kyle
Old 06-21-2007, 09:09 PM
Zero10's Avatar
Send a message via ICQ to Zero10
Fix the leaks and use a R12 hydrocarbon substitute.
If you need to, pick up a sniffer on EBay or use a flourescent dye to detect the leaks.
Low pressure is on th ebottom, and high pressure is behind the headlght/on the strut tower.
The fittings do just screw right on, most gauge and charging sets use the R134A fittings regardless of whether they are HC12 or R134A, so they are usually worth installing.
2010 Hyundai Elantra Touring, GLS 5 speed, Indigo Blue Metallic. 2.0L of Korean fury!
Buy my parts!
Old 06-21-2007, 11:32 PM
If you do change the connector/fitting type, remove the old shrader valve before you put the new fitting on. Didn't see that mentioned above, needs to be done.
91 FJ80
Old 06-21-2007, 11:49 PM
Eldorado's Avatar
the 134 valves screw on top of the old schrader valves, at least that's my understanding.
Kyle
Old 06-22-2007, 12:03 AM
Schrader is that the little coper rod that relives the presure like in a bicycle tire looks like this ---||-0 ?
Jaime O.
Old 06-22-2007, 10:51 AM
Eldorado's Avatar
i believe that's what he's talking about. it's threaded on the outside.
Kyle
Old 06-22-2007, 11:22 AM
There's no need to have two valves, dump the one on the compressor if you swap fittings.
91 FJ80
Old 06-22-2007, 07:36 PM
Zero10's Avatar
If you have a straight-through valve you leave the old valve in, if it's right angle or anything then you need to take out the old valve.
Buy my parts!
Old 06-23-2007, 12:04 AM
10-4 yes the valve inside the compressor is what i was talking about. And now i'm not so sure i'm going to do the freez 12 thing. My freind who's a mechanic said that it works great for a while but then turns realy stick oily gooey. not sure which word he used exactly but it was around those terms. So now im thinking it over. But then again if it goes bad i could force myself to update the whole a/c system compressor blah blah blah. So i'm not sure what im going to do.... I got very little time off of work and it's getting hot pretty soon .
Jaime O.
Old 06-29-2007, 10:36 AM
Eldorado's Avatar
funny... *my* mechanic buddy said go ahead and use 'em. lol
go figure...
it's all a matter of opinion, me thinks.
Kyle
Old 06-29-2007, 11:54 AM
unindicted co-conspirator
looneybin's Avatar
I used an r-134 conversion kit by "interdynamics" on my '86 944
it's available at kragen auto parts & comes with all the needed fittings & replacement oil etc.
no problems to date & A/C blows ice cold
The low side port is on the larger diameter pipe on the drivers side shock tower (not the port next to the pressure switch & drier)
'03 996 - sport exhaust, sport seats, M030 sport suspension, stability control, IMS Solution
‘86 928S3 - barn find project car
Old 07-19-2007, 02:28 PM
