Certified Porsche addict
The Glademister's Avatar
Door lock change
Worked on my drivers side door lock today. The key cylinder and interior knob were non-functional. Removed the door panel and sprayed some WD40... bingo... functioning interior lock but no dice on the key cylinder. I was beginning to suspect that the cylinder had been changed and when I tried the only spare key that came with the car... indeed it had. The ignition key fits the passenger door and the rear hatch. The small spare key fits the drivers door. So from what I've seen in the parts list it is possible to order spare keys and new key cylinders. But to get a cylinder to match an existing key it's asking for a number (and more money). Where is the key number documented? Also, how difficult is it to replace the key cylinder?
Tennessee Region SCCA & PCA
Current projects - '87 944 Turbo, '87 924S, '82 931, '10 Boxster (the girlfriend)
Past projects - '83 944, '02 Boxster (x2), '99 Boxster, '14 Cayman,'72 Opel GT, '75 280Z, '90 300ZX, '87 944S, '87 944 Turbo, '88 924S (x2), '07 Cayman S, '73 914, '88 MR2 AW11
Old 12-28-2007, 01:48 PM
Certified Rennwerker
924Sman's Avatar
Send a message via MSN to 924Sman
Go to the Porsche dealer, give them your VIN and request a key replacement. They will look it up and issue a new key. 2 weeks delivery at the most at a cost around 35 bucks w/o the black cover. Remove the old key from the OE black cover and replace it w/the new key.
Dal
PCA " I've been everywhere, done everything......just can't remember any of it!"
Old 12-28-2007, 02:32 PM
Thanks for your response but that doesn't really take care of the mis-matched drivers door and ignition locks. The ultimate solution is a lock cylinder that matches the ignition lock.
Old 12-28-2007, 02:45 PM
924Sman's Avatar
I am sorry I misread it. I thought the tumblers were OE, my error.
Old 12-28-2007, 03:45 PM
white944cup's Avatar
Check out this Tech Article from the Pelican library. It explains exactly what needs to be done to re-key your locks to make all your locks match one key. It sounds pretty easy. Unfortunately, I don't know where you can purchase the assortment of lock pins needed to do this.....if you have some old locks laying around, you can cannibalize the pins from them. Some people suggest that a good locksmith can do it, but I don't know any around my town that can. Maybe the Porsche dealer? I shudder to think what that might cost, if they can do it. If anyone out there knows a good locksmith that can do this, or where the lock pins can be found for DIY, please post a recommendation.
http://www.pelicanparts.com/techarticles/mult_lock_rekey/mult_lock_rekey.htm
1988 944 Turbo
Guards Red - Black Leather
Autothority Stage 2 Chip Set
Weltmeister Strut Tower Brace
1984 944 - Sold to rcecale
Old 12-28-2007, 03:46 PM
Nobody Special
I'm not familiar with the 924S but if it has the insert style door handles the original key code is stamped on the passenger door side handle. I used to have a photo somewhere. When you pull the finger lever the key code number is exposed on top of the inside part that gets exposed. It should have a code like 'VB4675' You might have to remove the door frame screw at the rear of the handle to tip it out far enough to see it. This assumes that the passenger door handle is original and the ignition tumbler hasn't been changed either.
86 - 951 - Garrett dbb T3/T4R/Tial/Maxtronic -SOLD
91 - BMW 325 iX AWD, 5-spd Coupe, Lazur Blau Metallic-SOLD
86 - 951-K26/8, daily driver-SOLD
87 - 944S - Another daily driver-SOLD
Old 12-28-2007, 03:47 PM
924Sman's Avatar
Might be ez to just buy a handle w/key used.??
Dal
Old 12-28-2007, 03:52 PM
Nobody Special
Dal
You seem to know your 924's very well. Does the 924S have the plastic insert type handles or the solid type on the later 944 models? If he can get that key code number he can buy a new cylinder for the drivers door without replacing the handle at all...much cheaper and then the car is keyed alike.
Old 12-28-2007, 04:11 PM
924Sman's Avatar
Tumbler is EZ to replace.
2tight......plastic cosmetic strip on the outer handle grip?
Old 12-28-2007, 04:32 PM
Nobody Special
The 924 and early 944 up to 85 used VW handles with a plastic trim strip that snapped on the outer handle. The 85.5+ 944 had solid handles or Porsche script handles with no plastic insert. I'm just not familiar enough with the 924S to know if it used early or late handles. The 924S used early interiors but some later parts like the 944 of the same years.
Old 12-28-2007, 04:43 PM
924Sman's Avatar
Early it is on a 924S.
Dal
Old 12-28-2007, 04:48 PM
924Sman's Avatar
Come to think about it I may have a spare tumbler for the man in need. Let me take look and I will get back to you, if I do it is free to you......Don't get too excited though!
Dal
Old 12-28-2007, 04:51 PM
Nobody Special
Dal
He needs a tumbler that matches his other locks though. I have 3 early tumblers also but I doubt if it would do him any good without a locksmith and a set of correct pins. It's good to know the later 924S used the early handles, now he can at least get the key code from the passenger side handle and get it matched.
Old 12-28-2007, 05:30 PM
Here's a photo of the passenger door handle. I'm not sure where the code would be located. I didn't see anything on the pull lever from the top or bottom.
Old 12-28-2007, 05:50 PM
Razorback1980's Avatar
Send a message via AIM to Razorback1980
I'm pretty sure a locksmith can set the tumblers to match the key...call your local locksmith to see what it costs as I have no idea but I don't think it will be that much.
Tom
1990 944S2 Cabriolet
2002 Chevy Silverado 2500HD
2003 Maroon Ford F350 dually
Old 12-28-2007, 06:29 PM
Nobody Special
The number is on the inside. This is a pic of a insert type handle with the finger pull depressed to show the keycode location. It's the same for all insert type passenger side handles.
Old 12-28-2007, 06:48 PM
Thanks 2Tight. That shows me how to proceed. This is a low priority fix anyway. I've got some other items on my project list that I'll tackle first.
Old 12-28-2007, 07:33 PM
GostRidr's Avatar
Make sure to let us know what you find out. I just took mine to a locksmith and had the doors and ignition matched (all three were different!) I don't think it was very much money and they did it pretty fast.
Good luck!
peter
1991 944S2 Cab, Crystal Silver Metallic "Platinum Banshee"
1987 944S Alpine White, Ice Shark Lights "Desert Ghost"
2015 Charger R/T Road & Track
Old 12-30-2007, 03:15 PM
Will do. Next fix will be the rear lid lift cylinders and a missing inner fender panel.
Old 12-30-2007, 04:17 PM
Semper drive!
rcecale's Avatar
Yeah, I know a guy that could really use this kind of recommendation!
Randy
84 944 - Alpine White
86 Carrera Targa - Guards Red - My Pelican Gallery - (Gone, but never forgotten )
One Marine's View
Igitur qui desiderat pacem, praeparet bellum
Old 12-30-2007, 04:41 PM
