She finally ran, but not for long
I finally got her all put backtoegther after new head, and 1700.00 worth of replacement parts. She started right up, ran ok i guess, i didnt push her. But, my temp guage on my instrument cluster that i paid 135 bucks for doesnt frekin work so i took her back home. I dont think my cooling fans were working either because they didnt come on.
after turning her off, i was making sure everything was tight and put together, i tried to start her back up, but nothing. anybody have any suggestions. thanks josh
1987 944 n/a
Old 12-04-2007, 05:59 PM
GostRidr's Avatar
Josh,
I apologize if the back story is in another post but I need more info. Is the temp gauge a stock replacement? Did the old one work before? As for your fans, how long did you warm up the car and run it? How old is your cooling system and what are the outside temps? I ask this because they will all affect how fast your fan comes on.
good luck,
peter
1991 944S2 Cab, Crystal Silver Metallic "Platinum Banshee"
1987 944S Alpine White, Ice Shark Lights "Desert Ghost"
2015 Charger R/T Road & Track
Old 12-04-2007, 11:34 PM
Certified Rennwerker
924Sman's Avatar
Send a message via MSN to 924Sman
Well start over, check the vacuum and electrical connections, grounds. Does it crank now after shut down, tach indicator bounce when cranking? Do a fuel check, FP coming on, pressure. Pull the fuel relay/DME relay and jump the connections to determine the relay has not fried. Read the proceedure at Clarks or search for post on it here.
Check the sender on the radiator that fires up the cooling fans and if it did not get to full temp upon your initial start they won't come on. Check the spaded wire on the head and the temp sender for function, cracked connection lead.
Dal
PCA " I've been everywhere, done everything......just can't remember any of it!"
Old 12-05-2007, 02:58 AM
mr. dude's Avatar
If the car is not turning over at all check your starter or it could be your ignition switch. If it's turning over but not firing could be a lot of things. I'd check your speed and reference sensors if your tach is bounching or if not check your fuel sending unit.
2006 Porsche Cayman S
2006 Lotus Exige (Sold)
1986 Porsche 944 (Sold)
1981 Porsche 931 (Wrecked)
1987 Porsche 944 (Sold)
Old 12-05-2007, 04:56 AM
924Sman's Avatar
Tach should bounce
Dal
Old 12-05-2007, 05:25 AM
cooling system is old, all the hoses have been replaced, the tach doesn't bounce, so what does that mean. When i turn it over, it just keeps turning over and the oil pressure slowly goes up as it cranks. what does that mean. I ran the car for about 20 minutes and drove it around never going above 30mph or 3000rpms. Its about 50 degress outside, the hood is removed.
i put gas in it, so its not that, ive checked all my connections, i think i need to fix a ground from the harness that has the temp sensor and the afm sensor plugs on it, its a yellow wire that somebody had taped to the alternator adjusting bar. but it ran before when that was undone and the wire was just hanging there.
1987 944 n/a
Old 12-05-2007, 03:00 PM
aj951's Avatar
Somebody back me up here but I think if the tach doesn't bounce, that means that you reference or speed sensor is either bad or disconnected. Did you replace you reference and speed sensors? If so, are they spaced correctly from the flywheel? If they were too close and made contact with the flywheel, they could have been damaged when you ran the car the first time.
89 944 Turbo
Guru Chip
Lindsey Boost Enhancer
3bar Reg.
Old 12-05-2007, 03:39 PM
i never took them out so they should be fine spacing wise, pieces of **** might be bad, but would that make the car not run? josh
1987 944 n/a
Old 12-05-2007, 03:52 PM
aj951's Avatar
Yes, bad sensors would keep the car from cranking. However, since you didn't replace them I doubt that they just went bad. There is a procedure on Clark's Garage on how to check them but you need an Oscilloscope. If you disconnected them from the DME harness when you replaced your head, I would recheck those connections as a quick check, perhaps they might be loose.
89 944 Turbo
Guru Chip
3bar Reg.
Old 12-05-2007, 04:11 PM
meister member
speedracing944's Avatar
IIRC isn't the mounting braket for the speed/ reference sensor connectors near the large ground cable which goes to the head. The ground terminates in the center top of the fire wall. Maybe it is disconnected there.
Speedy
1983 944 guards red with 16" Fuchs, Host of Wisconsin area timing/ balance shaft belt tensioning party
1987 944S Purchased from Legion. Corvette LT-1 V-8 conversion with Mega Squirt II
Check on progress ---> www.porschehybrids.com/gallery/speedracing944
Favorite Road = www.tailofthedragon.com 318 turns in 11 miles (11 min 20 sec best run)
Old 12-05-2007, 04:25 PM
Just thinking out loud
mattdavis11's Avatar
This probably isn't the problem since you had the head off, but you might want to check all the wires at the positive battery terminal. I had similar symptoms (no tach, no start) after replacing the battery connector. One wire was pretty corroded under the sheath.
91 FJ80
84 Ram Charger (now gone)
Old 12-05-2007, 04:31 PM
the tach needle does indeed bounce it was just darker last night so i couldnt see it but it is bouncing. ive checked everything 20 times and i just dont get it. it ran, and then i turned it off. and now it wont start. wtf????
all the batt. cables are brand new. i dont know what to do
1987 944 n/a
Old 12-05-2007, 05:31 PM
That Guy
Techno Duck's Avatar
Do you have... fuel pressure, spark? Are the injectors firing? Simply saying the car wont start does not help anyone figure out what the problem is.
Jon
1988 Granite Green 911 3.4L
2005 Arctic Silver 996 GT3
Old 12-05-2007, 05:43 PM
im testing all that now,
1987 944 n/a
Old 12-05-2007, 05:50 PM
924Sman's Avatar
The S/R sensors seems fine if the tach is moving so I think the answer is easier, pull the fuel relay and jump it per Clarks manual. Do this before anything else then go from there. Remember to pull the jump wire or it will run continuously.
Dal
Old 12-06-2007, 01:04 AM
ok i pulled the spark plug, and turned the car over and there was no spark so its not getting spark. I dont know what causes it not to get spark, its got everything brand new, coil, plugs, cap, rotor, wires, somebody know what i do.
i tested for fuel and its getting it. thanks josh
1987 944 n/a
Old 12-06-2007, 02:37 PM
924Sman's Avatar
I am going to back off that sensor thought.....Get a multi meter out and test the speed and reference sensors.....here are the specs
Speed Sensor:
600-1600 ohms between terminals 8 and 27
Infinite resistance between terminals 27 and 23
Reference Sensor:
600-1600 ohms between terminals 25 and 26
Infinite resistance between terminals 26 and 78.
Dal
Old 12-06-2007, 04:21 PM
Makis's Avatar
Do you have immobilizer? If so it may not work properly. Just a thought.
Old 12-06-2007, 05:48 PM
earlr85944's Avatar
pull the wire off the coil and check for spark there first
83 944....bye bye
85.5 euro spec 944, 5sp (she's gone....
74 914...hasta LA Vista baby
87 924s....don't let the door hit ya
68 912.......see ya!
Old 12-06-2007, 05:49 PM
thanks for all the help guys, we do have spark at the plugs, pulled one and dad turned the car over good spark. will chcck the fuel relay tomorrow
1987 944 n/a
Old 12-07-2007, 08:07 PM
