GostRidr's Avatar
Cloudy Cab Window
Hi all,
I'm looking at a cab with a cloudy window. The rest of the top is like new. I have heard that it is 'an easy fix' to replace the window but I haven't talked with anyone who has actually done it. Thanks for your reply if you know where to go (upholstery, marine...?), how much it costs and how successful it can be.
peter
1991 944S2 Cab, Crystal Silver Metallic "Platinum Banshee"
1987 944S Alpine White, Ice Shark Lights "Desert Ghost"
2015 Charger R/T Road & Track
Old 12-07-2007, 11:46 AM
winter-hater club member
nynor's Avatar
just for grins, try furniture polish on the cloudy window, both sides.
"COOL PRIUS!" - Nobody Ever
Old 12-07-2007, 12:02 PM
Luis de Prat's Avatar
Here's the deal. A cloudy plastic window cannot be "cleaned" or restored. Only replaced.
The amount of labor to replace the rear window on a 944 or 968 cab is almost as much as to replace the entire top, which consists of 2 sections.
If your top is "like new," then go ahead and have the rear window replaced only. Otherwise, I would have the whole top replaced. A good upholstery place will make it look perfect. Should cost in the neighborhood of US$600-800 plus the cost of the new top or window section.
The best tops for these cars are made by Robbins in CA.
Old 12-07-2007, 02:26 PM
flash968's Avatar
before you run out and buy a new top.........
i've "restored" plenty of the back windows that were brown and fully glazed
go to a plastics shop and get a bottle of Novus - it comes in three grades (1,2, and 3) - the higher the number the more abrasive - #2 usually does it, but i have had to use #3 on really bad ones - most effective using a dual action buffer, but can be done by hand
Old 12-07-2007, 03:23 PM
GostRidr's Avatar
awesome feedback guys. Thank you! The PPI turned up some other issues so not sure I will follow through. If I do, I will let you know. If there is anyone else with more keep em coming just in case!
Thanks!
peter
Old 12-07-2007, 04:12 PM
I guess it depends on what he means by "cloudy." The "cloudy" plastic window on my 944S2 cab when I bought it was like parchment paper. No amount of Novus would've brought it back.
I hope his "cloudy" window is like the "glazed" ones you're referring to.
Old 12-08-2007, 02:31 PM
Nobody Special
+1 on the Novus products. I've restored some pretty bad Miata windows using the stepped grades. They really do work well. They are even better on dull faded taillight lenses.
86 - 951 - Garrett dbb T3/T4R/Tial/Maxtronic -SOLD
91 - BMW 325 iX AWD, 5-spd Coupe, Lazur Blau Metallic-SOLD
86 - 951-K26/8, daily driver-SOLD
87 - 944S - Another daily driver-SOLD
Old 12-08-2007, 02:50 PM
nynor's Avatar
^i am going to have to try that. if only they could fix a cracked dash!
Old 12-08-2007, 03:58 PM
