Died. Cranks but no start
Oh boy.
I was backed down my driveway this afternoon, stopped in the road, went to put it in gear and... dead. So, I was temporarily in the middle of the road with a stalled engine. I hastily cranked... and cranked... and cranked... but no dice.
With the help of some kind bystanders, I pushed her back into the drive. An hour later, I tried again... still cranks but no starting. Could I have flooded it in my haste?
Really, I'm hoping so, because there's nothing else good. I did swap out the fuel pump fuse (upper fuse 2) because it was looking a little worn.
EDIT: Possibly a loose battery cable? I'll check on that in a little while.
'84 Porsche 944
Old 02-28-2008, 04:12 PM
Learned by do'n twice
944s have a number of common causes for the symptom you describe: bad DME Relay, bad DME, bad fuel pump or fuse, bad speed/reference sensor or their connection to wiring harness and probably a couple of others I've missed.
Despite the above common issues, cars needs 4 things to start: compression, fuel, spark, and timing. Since you were running, you must have recently had compression, so you can skip that for now. Timing: check through the view port at the front of your cam shaft gear while someone turns over the engine to make sure the timing belt is still intact and the camshaft is turning. Fuel: crack the nut at the front of the fuel rail after turning over the engine a few times. Fuel should spurt out under high pressure. Spark: Pull each spark plug and ground it against the engine block while turning over the engine. Verify spark is present.
Post back with the results and myself of someone will help further.
Loose battery cable?... From your post the car turns over just fine. Failure to turn over would be a better symptom of a loose battery cable.
86 944 NA - Brought back from the dead
Old 02-28-2008, 05:01 PM
hermesbooking's Avatar
Send a message via Yahoo to hermesbooking
Look at everything real good. I was having the same problems a few weeks ago. It would crank over just fine, had good fuel pressure, had spark. Had to jump the car to get it started. Come to find out after a few times of this happening to me. I was going to replace the battery, figured I would check the alternator at the parts store, just incase. Come to find out the Alternator was BAD! Installed a new one last week and have not had any issues. From this problem I found out from another Pelican that if you dont have the correct power to your injectors, they will not kick off. So you can crank all day, have everything to the rail, spark etc, but won't do any good without the injectors firing. Be sure to check everything real good. Hope this helps, Mike
I Love the Smell of Jet Fuel in the Morning!
86 Silver Porsche 944 N/A - Alpine CDA-9857
KYB Front, Weltmeister 250lb springs, MSD Master Blaster Coil, K&N Cone Filter, Blue LED Dash, Clock and Defrost Upgrade
http://www.c28.com/?adid=st&iid=25349
Old 02-28-2008, 06:11 PM
Once you jumped it, did it run well? I ask because, if this is my problem, I have about 20 miles to get to my shop of choice, or 100 miles to my brother's garage where we can do the work ourselves.
'84 Porsche 944
Old 02-28-2008, 08:13 PM
Razorback1980's Avatar
Send a message via AIM to Razorback1980
Check the fire and fuel as jmd described...that will tell the answer.
Tom
1990 944S2 Cabriolet
2002 Chevy Silverado 2500HD
2003 Maroon Ford F350 dually
Old 02-28-2008, 08:35 PM
martin944's Avatar
that happened to me a couple weeks ago. But, mine was because i ran out of gas. my fuel gauge ia a bit off. so I usually go by the mileage before I fill up, which is about 350 miles/tank full with a mix of fun/city/a bit of highway driving. I guess I was pushing it a bit, my mileage was about 340ish when it stalled out. The worst part was that the gas station only had gallon size containers, which they were selling for $10. I wanted to get at least 2 gallons in there to make sure the fuel gets to the injectors. So 2 gallons of gas cost me about $26 bucks.
Old 02-29-2008, 05:38 AM
Ouch...Expensive lesson!
Tom
Old 02-29-2008, 07:56 AM
martin944's Avatar
live and learn, .... when mine stalled, i felt that timing belt/broken cam tensioner chill up my spine.
Old 02-29-2008, 08:17 AM
winter-hater club member
nynor's Avatar
this happened to me. it was the timing belt.
"COOL PRIUS!" - Nobody Ever
Old 02-29-2008, 06:44 PM
Just thinking out loud
mattdavis11's Avatar
Does it sound like a sewing machine? Check the wires at the terminals, but if you have tach, that's most likely not the problem.
91 FJ80
84 Ram Charger (now gone)
Old 02-29-2008, 07:19 PM
no crank
most likely the dme fuel pump relay , 2nd one of the crank sensors , the dme relay can be crossed if you know just short out the relay , the cover can be removed and the realy can be bypassed with small wi re , or borrow one from friend crank sensor is expensive see if you canfind used one or borrow one 95 times out of 100it is one of these two , according to my long time porsche shop and my own experience hint keep dme fuel relay spare in glove box or learn how to cross wires to bypass thisrelay if it goes bad if either or both of these goes out you will sit fover until they are replaced btw do notexpect your shopor a porsche dealer to know this my friend spent 1200 bucks at porsche dea;ership and car still would not start it wasthe dme fuel pump relay fixed for less than 60 bucks after 3 weeks a ride home from the rdu airort and 1200 at local porsche dealers for hi goodto see you but we cannot start your car!
Old 03-01-2008, 07:14 PM
