meister member
speedracing944's Avatar
engine clatter with video. Is it a lifter???
I was able to capture the engine clatter on video. Here is a link... Listen and let me know what you think is the issue?
http://www.youtube.com/watch?v=ppYIcCPa3Ws
Symptoms....
Engine sounds normal when initially started up but after it warms up I get this noise. It is a loud clatter/tick which kind of oscillates. If you listen to the video you might be able to hear it. I used a screw driver and put it up to my ear and listened to the fuel injectors and I can hear them tick but it sounds normal. When I place the screwdriver against the cam tower or head the noise is apparent but I can't tell where it is coming from.
I had the cam tower apart last year and replaced some lifters as well as resealed everything. I am running some very light weight oil right now 5W30 and I usually run 20W50. I wonder if switching to a heavier oil would help since the noise isn't there during initial startup when the engine is cold and the oil is more viscus.
Let me know what you think...
Speedy
1983 944 guards red with 16" Fuchs, Host of Wisconsin area timing/ balance shaft belt tensioning party
1987 944S Purchased from Legion. Corvette LT-1 V-8 conversion with Mega Squirt II
Check on progress ---> www.porschehybrids.com/gallery/speedracing944
Favorite Road = www.tailofthedragon.com 318 turns in 11 miles (11 min 20 sec best run)
Old 05-19-2008, 09:48 AM
ERAU944's Avatar
Send a message via AIM to ERAU944
Speedy
i'd agree, try a heavier oil and see if that doesn't quiet things up. hopefully you didn't collapse a lifter by using that wateroil
Mike - CFI, A&P Mechanic w/ I.A., Aztec driver at Island Tyme
'88 951S - zermatt silber/black - staying stock. purchased in 11-2006
'84 944 - gemini grau/tan+brown - lightly modified. purchased in 11-2001
2021 Tesla Y - to get me to work
Old 05-19-2008, 09:55 AM
Sounds like the lifters...why would you run such light engine oil in an old car. You want to hear something crazy...my wife's brand new BMW runs on 5w30 and if I have not started it in a couple of days, the engine clanks on start-up. I think the
5w-30 should be reserved for the race track. I have always found that old engine love to run on stadard oils. The bottom line is you want your engine to last not try and gain .5 HP by putting some performace oil in your car.
1990-Porsche 944 S2 Project Hair Loss
2001-Saab 9-5 BSR Best car I have owned
2008-BMW 328i (Just another beamer)
Old 05-19-2008, 12:02 PM
meister member
OK OK I bought some SeaFoam and some ATF. I am going to put 1 quart of ATF and the can of Sea Foam in the crank case and run it for a bit, drain the oil, and refill with my normal 20W50 Mobil 1.
I will report what happens.
Speedy
Old 05-19-2008, 05:28 PM
Have you checked the front cam sprocket and the bolt that holds it on. A loose cam pulley will make quite a bit of racket.
Old 05-19-2008, 06:29 PM
Send a message via AIM to bholmes
hope the oil change helps. I actually had lifter clatter once from using a light weight oil. I usually run Mobil1 15w50 and it does fine, but once I tried a lighter oil and it made racket. good luck!
Brian
'86 944 NA
'94 Jeep Cherokee 3" and 31's
'86 Chevy C10 425hp
'98 Dodge Neon (the wife)
Old 05-19-2008, 07:20 PM
Nobody Special
Personally I wouldn't run 30W anything in a 944. In hot weather you are asking for disaster IMO. Have you tried the 15 or 20W-50 yet like others have suggested? I won't even run 40W, let alone 30.
86 - 951 - Garrett dbb T3/T4R/Tial/Maxtronic -SOLD
91 - BMW 325 iX AWD, 5-spd Coupe, Lazur Blau Metallic-SOLD
86 - 951-K26/8, daily driver-SOLD
87 - 944S - Another daily driver-SOLD
Old 05-19-2008, 09:10 PM
meister member
I have always run 20W50 Mobil 1 before but this spring when I was oil shopping it was still very cold outside and none of the stores had their thick oils on the shelf yet. Kind of like department stores waiting to put out the swimsuits until after the snow melts.
Speedy
Old 05-20-2008, 06:44 AM
meister member
No luck! I ran it for 30 minutes, drained the oil and put in 15W50 mobil 1. It still is clattering. I may have to look at plan B.
Hmmmm what was plan B again?????
Speedy
Old 05-20-2008, 08:26 AM
Back from Beyond
Definitely lifters, given that racket. What are your oil pressure readings?
'88 944 Auto - project, kinda
'87 944 Auto - died saving my wife
'84 944 5SP - crushed under shop roof during snow storm
All others GONE!
Old 05-21-2008, 12:05 PM
meister member
4.5 bar driving
4.0 bar at idle with the temp gauge at the 1/4 mark
Speedy
Old 05-22-2008, 06:21 AM
meister member
I think plan B is once I get the new roof on my garage I am going to tear off the cam tower and inspect the lifters and valve springs. If all checks out there tear off the head.
I AM NEVER BUYING PORSCHES CRAPPY IDA HYDRAULIC LIFTERS AGAIN!!!!!
Speedy
Old 05-22-2008, 06:26 AM
Send a message via AIM to unsigned
hmm... Might be a good time to work on that LT1 conversion...
'84 944 Black/Black
_______________
'04 GTO Black/Red - stock
'92 Maxima SE - Is it wrong when your Maxima has KONI Reds and your 944 doesn't?
'94 Maxima GXE - winter wheels.
Old 05-24-2008, 07:07 PM
How many miles on the engine speedy? Is it possible the cam lobes are seeing some wear finally and you just have some valvetrain slop? Sounds like an excuse for a webcams to me. I'm really not sure if there's any way to check the clearances on the valvetrain though...it's not like the ol' push-rodders i'm used to.
Brian
'86 944 NA
'86 Chevy C10 425hp
Old 05-24-2008, 07:24 PM
Did you check this out? Especially since:
Old 05-25-2008, 05:39 AM
meister member
I haven't had a chance yet. I am trying to reroof my garage before the storm hits and I also had a fellow Pelican out yesterday for timing/ balance shaft belt replacement.
Speedy
Old 05-25-2008, 07:01 AM
meister member
Speedy
Redline Racer
HondaDustR's Avatar
Speedy
You might want to rethink using the Mobil1...
(...throws a grenade and ducks for cover. )
http://forums.pelicanparts.com/showthread.php?t=367300
1987 silver 924S made it to 225k mi! Sent to the big garage in the sky
Old 05-25-2008, 08:48 AM
Back from Beyond
Loose cam sprocket makes car sound like diesel tractor. Not what I heard (although the sound quality through this computer isn't great...). Would cam wear be audible with pressure-fed lifters? I'm really interested to know what the issue is.
All others GONE!
Old 05-26-2008, 11:31 AM
