Arizona_928's Avatar
does a turbo cam tower....
does a turbo cam tower and lifters from a 951 fit into a N/A 944.
dolor et pavor
Copyright
Old 06-04-2008, 04:54 PM
fast924S's Avatar
Send a message via AIM to fast924S
I believe YES, but Im only about 80% sure
1986 951, Stock for now.
]87 924S Gaurds red- SOLD after 11 years of ownership
Old 06-04-2008, 05:02 PM
thoen's Avatar
8V. yes, same numbers.
Yellow 1983 944. Many alterations, modifications, repairations and aberrations. Great car!!
Old 06-04-2008, 05:28 PM
thanks! i'm off to ebay
dolor et pavor
Copyright
Old 06-04-2008, 06:11 PM
winter-hater club member
nynor's Avatar
it does have different lift and duration on the cam, IIRC.
"COOL PRIUS!" - Nobody Ever
Old 06-04-2008, 06:20 PM
so would that affect porformance on a N/A for better or worse?
dolor et pavor
Copyright
Old 06-04-2008, 06:40 PM
nynor's Avatar
not sure, but i think the duration and lift on the NA cam is higher and longer, so worse. i could easily be wrong, however.
Old 06-04-2008, 06:59 PM
Redline Racer
HondaDustR's Avatar
I'm pretty sure I've heard that, too. The turbo people sometimes use NA cams for that reason.
1987 silver 924S made it to 225k mi! Sent to the big garage in the sky
Old 06-04-2008, 07:50 PM
Dog-faced pony soldier
Porsche-O-Phile's Avatar
Yes, an n/a cam is an upgrade to a 951 actually (pretty sure just the early n/a cams).
Black Cars Matter
Old 06-04-2008, 10:05 PM
Redline Racer
HondaDustR's Avatar
Why just the early cams? Were they more aggressive, or were the bearing sizes or something like that just different?
Old 06-05-2008, 08:38 AM
Not Special
http://members.rennlist.com/951_racerx/CamProfiles.pdf
Early and turbo cams are the same. A late NA cam is a turbo upgrade.
Since the original poster has an early 944, the turbo cam is the same part number.
Current: 1989 Porsche 944 S2 - Baltic Blue/Linen
Former: 1985/1 Porsche 944 - Graphite/Black
Old 06-05-2008, 09:29 AM
Back from Beyond
^+1 It's also an early NA upgrade.
'88 944 Auto - project, kinda
'87 944 Auto - died saving my wife
'84 944 5SP - crushed under shop roof during snow storm
All others GONE!
Old 06-05-2008, 11:44 AM
Not Special
I don't follow, since the early NA cam is the same as the turbo.
Unless you're saying a late NA cam is an upgrade for an early, in which case that makes sense.
Old 06-05-2008, 12:36 PM
Back from Beyond
Yeah, that's it. Late NA cam in early NA car. George B set me up with this a long time ago and it did make a difference.
All others GONE!
Old 06-06-2008, 10:17 AM
Redline Racer
HondaDustR's Avatar
The late NA cam is an upgrade for either an early NA or any turbo, since the early NA cars and the turbos use the same slightly less agressive cam.
Old 06-06-2008, 04:07 PM
that sums it up.
dolor et pavor
Copyright
Old 06-06-2008, 05:15 PM
I have another queston but am kinda lazy to start another thread.
what are the lifters? cam followers or what? also if you have a lifter that collapsed do you just have to replace the lifter or is their anything else that goes on it?
dolor et pavor
Copyright
Old 06-06-2008, 05:18 PM
Redline Racer
HondaDustR's Avatar
Start another thread you lazy bum!!
Hmm, should I tell you anyway?... Nah..
Old 06-06-2008, 05:22 PM
i'll take a shot at it.
because you're a cool guy?
dolor et pavor
Copyright
Old 06-06-2008, 08:35 PM
nynor's Avatar
the lifters, in our case, are the things that contact the cam and compress the valve springs. if you have a collapsed lifter, you replace the lifter. there are no cam followers (tappets) as such, just the lifters.
Old 06-06-2008, 09:09 PM
