unclemikeys2001's Avatar
cooling fan problem ...resolved
Still havent sorted out the issue with my 83 944 na , parked it instead. ...Now Im tring to get it fixed so I can get on the road without overheating. The car runs great, when engine comes up to temp & fan comes on it will melt a fuse every time. Previous suggestions all said fan motor going bad. I pulled the fans & they both spin freely by hand & operate smooth when hooked up to 12v directly. So what could be causing the fuse to pop every time? Anyone know what kind of resistance reading I should be getting from the fans while I have them pulled & at what volts I should be bench testing them at. ....Im also thinking I have a short somewhere or something grounded out, but all wires I can see so far look good & clean with no tampering. Any help is appreciated. Thanks in advance.
1983 944 5 spd, w/ 1984 n/a motor + countless parts from 3 parts cars over the years.
Old 07-27-2008, 08:35 PM
Just thinking out loud
mattdavis11's Avatar
Do the fans come on when the a/c is turned on? Does it pop fuse 6 when the a/c is turned on? Does fuse 3 pop? If fuse 3 pops, chances are that the resistor is bad. If fuse 5 is blowing, it could be the relay acting funny.
91 FJ80
84 Ram Charger (now gone)
Old 07-27-2008, 09:04 PM
Politically Incorrect
onZedge's Avatar
Do the fans spin freeley? Which fuse number?
Edek
'87 924S
'91 535i
Old 07-28-2008, 05:08 AM
Fuse #3 is the one melting. #6 does not melt. Both fans spin free by hand. With key forward & AC on only the drivers side spins....I flipped fans upside down to reverse fans & same result, drivers side spins with AC on. Passenger side never turns but I know for sure both fans are ok now. .....Does the car need to be actually running & Hot before both fans will turn on with AC on? .....So when car warms up & passenger side fan kicks on is when the fuse melts.
Old 07-28-2008, 08:10 AM
Toofah King Bad
Rasta Monsta's Avatar
Check the fan wiring. The small harnesses have a tendency to get "involved" with belts if they aren't strapped down properly.
» 1987 924S Turbo - Got Boost? «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 07-28-2008, 08:15 AM
I checked those harnesses out real good. Nothing damaged. ....Ive searched all over Clarks & Pelican & come up with no help to my problem. Most info is for later cars. I would like to swap out whatever resistors I can from a parts car I have but dont know where to find them. ....I also see that the #3 fuse works the power antenna, well the antenna has not worked in my 5 years of owning the car so not sure if that matters since it hasnt been an issue in the past.
Old 07-28-2008, 08:52 AM
Proprietoristicly Refined
John_AZ's Avatar
Since you enjoy looking up at the dash from the drivers floor.
http://www.924board.org/viewtopic.php?p=222418#222418
John_AZ
1988 924S + 1987 924S
Old 07-28-2008, 11:53 AM
Well I decided to pull the relay & that wasnt easy, it was practially siezed in place. I had to pull the fuse box down to get it out. After I pulled it out I seen it was the original made in 04/83 ...Inside the relay is a definate burnt spot. I swapped it with a relay from a parts car & now I have some results. ...With key forward & AC on the drivers side spins on low speed & passenger on high. I havent put everything back together because I noticed my lower radiator hose has a VERY thin spot caused by the pass fan rubbing on it over time. Wanted to replace that 1st & so its off to buy one today & then the real test...to see what happens when the fan kicks on after warming up. Im keeping my fingers crossed its that simple. ....Anyways, does anyone know what is an acceptable level of resistance for the fans? They test good but do have different degrees of resistance.
Old 07-29-2008, 07:48 AM
FIXED.... simple as a burnt original relay. Fans now work properly & all is normal under running conditions. ...I decided to replace my lower hose while at it since the passenger side cooling fan had rubbed it very thin in 1 spot. I noticed the new hose I bought was a bit shorter than the original which made a better fit & took the hose away from the fan just enough. .......Thanks to all that have helped.
Old 08-10-2008, 12:15 PM
