Wheel Stud Problem
The last person who put wheels on my car way over-torqued them (> 200ft-lbs). I was able to break all of them free except for the (factory) wheel lock nut on one of the rears. It sheared half the lug and stud.
I took it to a (new) tire place that couldn't get it off. They recommended a brake-specific place. Good idea? I'm guessing it will have to be drilled and the stud replaced. Is it difficult for a rear wheel on a 944? The drilling out part is something I have neither the tools nor inclination for.
-Stephen 00 Boxster S 6MT 03 Subaru WRX w/EJ207 swap 16 Cayman GT4 21 Genesis G70 3.3T |
if half the lock lug is off, u should be able to just hammer-chisel out the other half and remove the wheel. then should be able to get some pliers or something and remove the stud.
def go slap the PO upside the head. he should know better than to impact wrench on lugs. |
Use this tool it work good on my 87 930 when the factory wheel nut broken in half and save the rim.
![]() Home depo have them 10mm is the good size , just be gentle when it come close to the rim Good Luck Bud |
snap-on makes a tool specifically for this purpose
For sure. I bought one from Snap on as well and cost Snap On Price.
Then I bought another from Home Depo and paid Home Depo price, made by RIGID |
the snap on tool does not look like the hole saw pictured above - it looks more like the reverse of an "easy-out"
Redline Racer
Yeah, craftsman makes the same kind of thing, too. Should be available at any Sears.
1987 silver 924S made it to 225k mi! Sent to the big garage in the sky |
