No spark #2&3
1983 944 5 speed, 10K miles. Drove car on nice sunny day a few weeks ago. Drove into garage and parked car.
Another nice sunny day, I went to drive the car again.
Started car, ran very rough.
Checked plugs and wires, no spark on #2 & #3. #1 & 4 spark. Anyone have any ideas??
TIA
Craig
Craig C. Laughlin CAMP 914
Helping to bring your 914 into the 21st century.
http://www.camp914.com
Old 03-12-2009, 09:42 PM
Bad distributor cap or bad ignition wires on 2 and 3.
Good luck, George Beuselinck
Old 03-13-2009, 04:38 AM
Okay, tonight I swapped out the plug wires, and the ECU. No change.
Craig
Old 03-13-2009, 08:39 PM
check/swap/replace the dist cap
Bruce P.
2011 Cayman Base, LSD, Sport Chrono.
1988 951 totaled and missed
"You're the best I ever had" --JJ Cale
Old 03-13-2009, 08:59 PM
Not many other places to go but the cap.
Craig
Old 03-13-2009, 09:02 PM
TibetanT's Avatar
Purchase a new distributor cap and rotor from our sponsor, Pelican Parts.
Since you swapped out the plug wires and it made no difference, that is my best guess at this time, with this information.
Good luck and let us know how else we can help.
Ed Paquette
1983 911SC
1987 944S
1987 944 Manual (Donated to the Nat. Kidney Foundation)
1987 944 Automatic (Recently sold to another Pelican)
Old 03-13-2009, 09:15 PM
I am planning to replace the cap, but I am not looking forward to replacing the rotor, knowing what is involved.
Craig
Old 03-13-2009, 09:23 PM
It won't be the rotor, but you should have one on hand anyway.
Old 03-14-2009, 05:01 AM
The cap was a bigger problem than the rotor for me. If you are going to replace them then the possibility of destroying the old parts should not be major. On mine the rotor had two threaded holes in the shaft and two holes in the rotor. It was done as part of timing belt, water pump, front seals, etc. and I put the rotor on 180 degrees off. Cost me a lot of time and heart ache.
85.5 N/A 944 Guards Red, 2005 Toyota Camry,
2005Toyota Tundra, 2000 Toyota Four Runner
2002 Honda Civic, 2007 Kabota Z28 Zero Turn Diesel
Old Toyota L345 Tractor, I wrench them all !!!
Old 03-14-2009, 05:12 AM
New cap, no change, still no spark on 2 and 3.
Anyone care to offer a suggestion.
I am stumped.
CCL
Old 03-14-2009, 02:09 PM
PRMN944
May be you had a bad rotor instead of distributor cap.
It is best to replace both to move on to something that is
causing the problem.
Old 03-15-2009, 08:15 PM
Okay, new plugs,wires,cap and now new rotor. Still no spark on #2 & 3.
Old 03-15-2009, 10:04 PM
sorry if im stealing your thread, i have the same issuse, but no spark on any.. i see you replaced the ECU, where is this located?
Old 03-16-2009, 02:25 AM
It is located under the dash, drivers side right above your knees.
Craig
Old 03-16-2009, 08:34 AM
PRMN944
Take the cap out and check the metal terminal if it has slight burn or scoring on
#2 and #3 and compare to #1 and #4. The dust cover should be in placed.
Remember, only Bosch cap and rotor will do.
May be you could show some pictures.
Old 03-17-2009, 03:08 PM
No spark #2 & #3
Properly installed, brand new BOSCH rotor and cap. No scoring or burning evident
on any of the posts inside the cap.
Not sure what pictures would show??
CCL
Old 03-17-2009, 04:48 PM
PRMN944
When checking the spark plugs, how is the conditons of all plugs? After cap
and rotor installed, did you start the car and let it run ? If you did, the cap or rotor
should have tiny scoring or brown coloring.
Find out if you have a good voltage coming out from the coil.
Do you have an OEM ignition coil or after market?
Mine is 1983 944 also.
Old 03-18-2009, 09:23 PM
Problem was found to be a crank sensor. It was the run sensor, even though the car would start.
Thanks to all who took the time to reply.
Old 03-30-2009, 08:41 PM
