front right locks up on braking!
On hard braking my front pass. side wheel locks up and slides, it's always the same wheel and it seems to lock up way before the other three. Any thoughts?
1991 cabriolet (sold) 1989 S2 1988 S 1987 944 n/a (sold) 1987 944 factory yellow (junked )
forgot to mention, it is an '88 944S:
Will program for food
caliper is sticking would be my first thought, maybe time for a rebuild.
Greg Hnat 87 Targa Disassembled 90 944 S2 Auto-x, DE and semi-daily driver 98 Jeep Cherokee |
Take the caliper off the car, clean it up real good, and use a little grease where the caliper slides back and forth on the bracket. Don't get too crazy with grease, you don't want it on your brakes.
It may be getting dirty and maybe a little rusty in there. If that does not work then rebuild or replace the caliper.
John '87 944 N/A (first Porsche) '95 E-350 Diesel '03 S-Type Jag 3.0 '03 Taurus SES '06 Eddie Bauer Explorer RIP SoCal |
Be sure to consider that the *other* caliper might not be working, causing that one corner to do all the work...
I think all the others are ok, I can lock up all four corners if I try. I was thinking maybe a brake system bleed, the caliper doesn't seem to be sticking, it releases as soon as i let up on the pedal a little
Hi, it could be the rubber line going to the caliper
thx all, I'll check it out a little further when i get a chance, the braking otherwise is good
Toofah King Bad
Could be a blown strut too.
» 1987 924S Turbo - Got Boost? « "DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc |
I'm sure you have already checked, but the tire on that corner could possibly be bald and the other 3 not bald... ?
How black is your brake fluid in the resivour?
- Elliott Grafton - 944Barn |
Tires seem alike, the rears are actually a bit more worn than the fronts, I don't think it's the strut, their is no bouncing or steering probs. the fluid is black, should i replace it all?
Yes, replace the black broken down fluid with fresh dot 3 brake fluid.
I like ATE Super Blue. Good stuff with a high boiling point.
Measure the thickness of the rotors. The wife (girl friend at time) had a old Honda, I replaced the pads on the front. Took me hours to figure out why the brakes were locking up. The rotors were thinner then the minimum thickness.
Rick 99 996C4 06 525XI 87 944S - Sold 77 924 - Sold |
ok, I'll check the rotors and def. replace the fluid.
The car looks great - what kind of wheels are those?
Good luck and let us know if/how you solve it.
Red 83 944 Last edited by AKCJ; 08-06-2009 at 09:13 AM.. Reason: spelling |
Thx. I believe they're called Cup 2's
I thought the 994 S had a Turbo front end or was that the S2? not knocking you or nothing just trying to get my facts straight.
no, the '87S & '88S do not have the turbo body work, Only from the '89S2 and onward, here's a pic of a '91 S2 cab, and a pic of an '89 S2 in front of an '88S and an '87 non S, also the turbo models from '86 on all had the bumper of which you speak
