callmethewander's Avatar
front right locks up on braking!
On hard braking my front pass. side wheel locks up and slides, it's always the same wheel and it seems to lock up way before the other three. Any thoughts?
1991 cabriolet (sold)
1989 S2
1988 S
1987 944 n/a (sold)
1987 944 factory yellow (junked )
Old 08-02-2009, 03:54 PM
forgot to mention, it is an '88 944S:
1989 S2
1988 S
1987 944 n/a (sold)
Old 08-02-2009, 03:58 PM
Will program for food
ghnat's Avatar
caliper is sticking would be my first thought, maybe time for a rebuild.
Greg Hnat
87 Targa Disassembled
90 944 S2 Auto-x, DE and semi-daily driver
98 Jeep Cherokee
Send a message via AIM to Icey1174
Take the caliper off the car, clean it up real good, and use a little grease where the caliper slides back and forth on the bracket. Don't get too crazy with grease, you don't want it on your brakes. It may be getting dirty and maybe a little rusty in there. If that does not work then rebuild or replace the caliper.
John
'87 944 N/A (first Porsche)
'95 E-350 Diesel
'03 S-Type Jag 3.0
'03 Taurus SES
'06 Eddie Bauer Explorer
RIP SoCal
Old 08-03-2009, 05:06 AM
Be sure to consider that the *other* caliper might not be working, causing that one corner to do all the work...
Old 08-03-2009, 07:11 AM
I think all the others are ok, I can lock up all four corners if I try. I was thinking maybe a brake system bleed, the caliper doesn't seem to be sticking, it releases as soon as i let up on the pedal a little
1989 S2
1988 S
1987 944 n/a (sold)
Old 08-03-2009, 03:22 PM
Hi, it could be the rubber line going to the caliper
Old 08-03-2009, 06:24 PM
thx all, I'll check it out a little further when i get a chance, the braking otherwise is good
1989 S2
1988 S
1987 944 n/a (sold)
Old 08-04-2009, 02:56 PM
Toofah King Bad
Rasta Monsta's Avatar
Could be a blown strut too.
» 1987 924S Turbo - Got Boost? «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 08-04-2009, 04:34 PM
drift a 944's Avatar
I'm sure you have already checked, but the tire on that corner could possibly be bald and the other 3 not bald... ?
How black is your brake fluid in the resivour?
- Elliott Grafton - 944Barn
Old 08-04-2009, 06:05 PM
Tires seem alike, the rears are actually a bit more worn than the fronts, I don't think it's the strut, their is no bouncing or steering probs. the fluid is black, should i replace it all?
1989 S2
1988 S
1987 944 n/a (sold)
Old 08-04-2009, 07:03 PM
Yes, replace the black broken down fluid with fresh dot 3 brake fluid.
Old 08-04-2009, 07:11 PM
ghnat's Avatar
I like ATE Super Blue. Good stuff with a high boiling point.
Greg Hnat
98 Jeep Cherokee
Old 08-04-2009, 07:47 PM
Measure the thickness of the rotors. The wife (girl friend at time) had a old Honda, I replaced the pads on the front. Took me hours to figure out why the brakes were locking up. The rotors were thinner then the minimum thickness.
Rick
99 996C4
06 525XI
87 944S - Sold
77 924 - Sold
Old 08-05-2009, 03:28 AM
ok, I'll check the rotors and def. replace the fluid.
1989 S2
1988 S
1987 944 n/a (sold)
Old 08-05-2009, 02:21 PM
The car looks great - what kind of wheels are those?
Old 08-05-2009, 07:39 PM
AKCJ's Avatar
If you do grease it up consider using high temp brake caliper grease. Regular grease would be more likely to just melt and drip off quickly.
Good luck and let us know if/how you solve it.
Red 83 944
Old 08-06-2009, 09:12 AM
Thx. I believe they're called Cup 2's
1989 S2
1988 S
1987 944 n/a (sold)
Old 08-09-2009, 06:05 PM
I thought the 994 S had a Turbo front end or was that the S2? not knocking you or nothing just trying to get my facts straight.
Old 08-09-2009, 08:20 PM
no, the '87S & '88S do not have the turbo body work, Only from the '89S2 and onward, here's a pic of a '91 S2 cab, and a pic of an '89 S2 in front of an '88S and an '87 non S, also the turbo models from '86 on all had the bumper of which you speak
1989 S2
1988 S
1987 944 n/a (sold)
Old 08-10-2009, 10:20 AM
