All Spooled Up
Oil dipstick bolt.
What is the trick to loosening and tightening it? I've had very much trouble getting at it with common wrenches & tools.
>gray 89 951S - K27/8, MAF, 3" intake, 3" exhaust w/separate waste pipe, 55# inj, late cam; >red 87 924S - chip, K&N, punched-out cat&muffler >black 80 924 - (sold) >maroon 77 924 - auto (sold)
Old 09-01-2009, 09:33 AM
That Guy
Techno Duck's Avatar
Guessing on a 951...10mm with built in wobble and decent size extension. That bolt is a real pain. Slot the bracket on the dip stick to make life easier.
Old 09-01-2009, 09:45 AM
In the Fires of Hell.....
kdjones2000's Avatar
I use a pivoting gearwrench. Getting it started is the only hard part.
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost
Old 09-01-2009, 01:04 PM
strath44's Avatar
yeah this is a total pain for some reason and the slight tension of the bracket and stick holder against the bolt in my experience causes the bolts to ping off and drop down the side of the engine on the ground!!
1991 944 Turbo
2012 VW Passat
2008 Mini Cooper
Old 09-01-2009, 01:14 PM
Not that I really wanted to revive this old thread, but OMG! I've had this intake off countless times, and yes it was always a little tricky to get the dipstick bolt back in. I've always won the little battle. Today I had to give up, and cry uncle. I zip tied the thing. I'll be slotting it next time.
86 951 blk
Old 04-25-2015, 11:14 AM
Piece of cake! I use 1/4" drive with 5" extension and 10mm socket with built-in wobble.
Put the bolt into the socket 1st, then hold it all together with a magnet-on-a-stick and use that to keep the bolt in the socket and guide the whole thing home. The whole thing takes 10-15 seconds max. I can make a video if you want to see.
Old 04-25-2015, 08:49 PM
Toofah King Bad
Rasta Monsta's Avatar
Switch to a stud?
» 1987 924S Turbo - Got Boost? «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 04-26-2015, 12:06 AM
I find it much easier to attach the dipstick tube to the manifold before putting it back on the car (the dipstick tube just pulls out). Leave the dipstick-manifold bolt slightly loose and then just tighten it after putting the manifold/dipstick assembly back in the engine. Just be careful not to damage the o-ring on the dipstick when you slide it back into the sump. (Since I once cut one, I actually keep a couple of spare o-rings around, they're cheep, just in case.)
Old 04-26-2015, 04:48 PM
Brap
tmaull's Avatar
Does anyone have a length or part number for this M6 bolt? The car I recently purchased is missing this bolt, so I had a little anxious moment when I pulled the whole tube out a few hundred miles from home.
1980 911SC Coupe 3.4
1995 Miata
2005 Tacoma
2009 Street Triple
Old 04-19-2020, 09:14 AM
