kvnhpnr's Avatar
Porsche Crest Slow Acceleration
Recently I changed out the water pump on my 1986 and I also changed the distro cap and rotor. I added RESTORE for 4 cyl engines and injector cleaner along with a higher octane gas the last time I filled up. Why am I still getting slow acceleration, don't get me wrong once it gets up to speed it goes like a bat out of hell but it is getting there that takes the time. Any suggestions?
Old 09-06-2009, 10:17 AM
when you reset timing, did you set it at a tooth and a half past the timing mark, or right on the mark?
when i redid the belts on my 88, i set it at the timing mark and it ran like that, till you got up to about 3000rpms.
Old 09-06-2009, 06:33 PM
kvnhpnr's Avatar
Porsche Crest Acceleration Problem
I set it right at the mark since the Haynes manual said to do that...but I adjusted the throttle cable and it is better than it was. I may end up replacing the throttle cable later. Right now the way I have it it hits about 3000 rpm and goes like a bat outta hell, ok a 23 year old bat, but still better than it was.
Old 09-22-2009, 04:45 PM
Redline Racer
HondaDustR's Avatar
Is this something that you noticed has changed from a previous state, or has it just always seemed slow? These motors, especially with the wimpy low rpm ignition advance of the stock maps, don't have a whole lot below 2500 rpms and just don't start cranking any serious power until about 4000 rpms. A good aftermarket chip will liven up the low end considerably. The other thing that could do that is a lean condition. Check that the FQS in the DME unit is in the normal position (fully counter clockwise), check for vacuum leaks, check the AFM resistor track ( http://www.the944.com/afm.htm ), check for low fuel pressure, check that the WOT switch is working.
1987 silver 924S made it to 225k mi! Sent to the big garage in the sky
Old 09-22-2009, 05:30 PM
Avatar's are to SMALL.
Send a message via Skype™ to cvriv.charles
Just what I was going to ask.
1986 951 - Wrecked. Being used for engine swap and parts.
1987 944 - SCCA specification track/ street car. Awaiting 951 engine and parts.
Old 09-23-2009, 03:53 AM
Proprietoristicly Refined
John_AZ's Avatar
kvnhpnr has a '86 944 automatic.
http://forums.pelicanparts.com/porsche-944-turbo-turbo-s/496409-intstrument-cluster-door-panel-removal.html
This is typical of the car. Just enjoy the car on the road and in the hills.
GL
John_AZ
Old 09-23-2009, 04:48 AM
