shikzachaser's Avatar
need help w/ pressurizing intake manifold
I could use a little help. I made a manifold pressurizer out of a universal fuel filter and some 1/2" hose w/ an air fitting. I set the pressure to a shade over 15PSI and clamped the filter to the boot after removing the AFM. The question I have is:
Air is coming out of the oil fill tube. Is this normal?
The car has been running like S--- and I have done the normal:
New plugs, cap, fuel filter, drained the tank and checked the strainer, etc. It idles but has no power (barely runs) until around 3K then it catches. I have maybe 15K on new OE injectors, new plug wires, AFM seems fine when I move the barn door. It acts like a large vacuum leak except the idle is decent.
Any input would be greatly appreciated
84 944 (my favorite all time car)
98 M3 (the wife's)
ML55AMG
03 Eurovan
00 Land Rover Disco II
Old 09-15-2009, 05:27 AM
Toofah King Bad
Rasta Monsta's Avatar
As for pressurizing the manifold, I am unconvinced it is possible with the camshaft installed.
» 1987 924S Turbo - Got Boost? «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 09-15-2009, 06:10 AM
