How to tell a real S
I purchased an 87na and was told it was an S model. How do I verify that?
Old 02-13-2010, 07:15 AM
Well... for starters it should have a sixteen valve engine in it.
Keith Belcher
'87 951 nautic/cancan
Old 02-13-2010, 07:25 AM
16v Motor and the 944S badge on the rear end are dead giveaways....
Old 02-13-2010, 07:37 AM
How do I tell if it has the 16 valve engine?
Old 02-13-2010, 07:47 AM
Mark944na86's Avatar
Location: Brisbane, Australia (Formerly: Sunnyvale, CA)
Cam cover will be double width (because it covers two cams instead of one).
It will look like this:
Currently 1990 944 S2, Black on Linen, 17" Turbo Twists
Old 02-13-2010, 08:05 AM
Custom User Title
Dave L's Avatar
Old 02-13-2010, 08:09 AM
944s
Just as I suspected, it is not an s after all. It has the s badge, but not the 16 valve engine.
Old 02-13-2010, 08:48 AM
Gee, I guess that it's easier to stick on an S badge than it is to put in a 16V motor.
Kind of like the VW GTI wannabes, or the boss I used to have that put IROC-Z stickers on his camaro... we used to call it the pseudo-IROC.
Good luck, George Beuselinck
Old 02-13-2010, 08:56 AM
meister member
speedracing944's Avatar
I saw the same thing one time at 944Fest. The guy seriously thought it was an S but it had an old 8 valve motor in it.
Either a real S with a replacement 8 valve motor
Stock 944 with a S badge on the back.
1983 944 guards red with 16" Fuchs, Host of Wisconsin area timing/ balance shaft belt tensioning party
1987 944S Purchased from Legion. Corvette LT-1 V-8 conversion with Mega Squirt II
Check on progress ---> www.porschehybrids.com/gallery/speedracing944
Favorite Road = www.tailofthedragon.com 318 turns in 11 miles (11 min 20 sec best run)
Old 02-13-2010, 06:13 PM
ernie9944's Avatar
Or you open the hood & see this LOL
83-944 show room -sold___New ride 93-968 with SC steering wheel-ROW signal ligths- Susp M030 mods lowered,Porsche VA springs- Adjustable struts - Bilstein inserts - Bilstein sport rear -LSD -riding on Cup 1 wheels 17x8 frt 17x9.5 rear road contact Falken 452/ 225-45 ZR Front 255-40 ZR Rear -- Motor Mods /chip /K&N / mod air boxe just love the handling & power
Old 02-13-2010, 07:06 PM
Endat's Avatar
This is the S engine.. the airbox is in the front and it says "16ventiler" on it. it should also have a badge on the fender that says "16ventiler". Aside from that the S has bigger brakes, a different transmission and maybe airbags and ABS
Some people think the '88 and '89 944's are S's because their 8v engine is bigger and 20hp more powerful, but the S is a significant 40hp more than normal.. and mine is about 15hp shy of the turbo.
Old 02-13-2010, 07:33 PM
Non Compos Mentis
The 2.5 S has the same brakes as the 8-valve. The 3.0 S2 has the same brakes as the 951 (minus the front cooling scoops).
Old 02-13-2010, 08:03 PM
meister member
Redline on the dash is higher than the normal 6400 RPM for the 8 valve. IIRC it is around 6800 RPM
Speedy
Old 02-14-2010, 03:33 AM
My 1990 S2 has the scoops.
Old 02-14-2010, 09:46 PM
J1NX3D's Avatar
I hope you didnt pay 944S money!
https://www.instagram.com/kiwi944s3/
'86 944S3 conversion
- '94 968 3.0 engine
- 6 spd/LSD
- 17x8,17x9 Oz Racing Crono wheels
Old 02-14-2010, 11:14 PM
Eric 951's Avatar
You are speaking of a 944 correct? If it was an 87 924, it would definately be an "S"
Eric
83 911SC/83 944
bunch of Honda 750s
Old 02-15-2010, 06:00 AM
On Boost
Paulyy's Avatar
post pictures of the back, front, sides & engine, we will happly tell you
86 952 GTX3076R, M-Tune, eBoost 2, CEP/JME cam, CEP head.
Old 02-15-2010, 07:04 AM
Eric is correct. An '87 924S would have an 8v engine identical to a 944. What did you buy? A 944S should have a 16v engine. I have read concerns about expensive repairs due to the cam/chain/head design, it is possible that it is an S, but to save money after an expensive failure, a PO swapped in an 8v engine. It is possible a PO installed an S badge on a 944. Both those scenarios are bad form if you are selling the car as a 944S. If it is a 924S, things are probably correct.
'86na, 5-spd, turbo front brakes, bad paint, poor turbo nose bolt-on, early sunroof switch set-up that doesn't work.
Malo periculosam, libertatem quam quietam servitutem.
Old 02-15-2010, 12:32 PM
A 924S is the old Narrow body and says 924..... Its hard to mistake them for a 944S.... I'm betting we have a 944na badged as a 944S.... or maybe not even badged... Just a lying seller...
Old 02-15-2010, 12:41 PM
J1NX3D's Avatar
iirc, both th e 944S2 and 968 have scoops, they're just shaped differently. I could be confusing the 968CS into the mix also. partno's on PET should tell the story. i.e. that the 944S2 and 968 scoops are the same and the 968CS is a better design...
- 6 spd/LSD
Old 02-15-2010, 03:13 PM
