High compression
I did a compression test on my car and it came out quite a bit higher than the 145 psi low tolerance limit. It said in the instructions that it could be carbon build up. Has anyone else had this experience?
Old 12-05-2001, 02:01 PM
Blackfoot's Avatar
what is the year of your 944? and what were the readings?
Old 12-05-2001, 02:12 PM
3sonfather's Avatar
Consider yourself lucky.
Old 12-06-2001, 09:57 AM
88, the readings were up around 180 or 200
Old 12-06-2001, 01:57 PM
Scott R's Avatar
Congratulations! Those are great numbers! I think the 145 range is too low. Haynes says 145, but many members here say those numbers are incorrect.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 12-06-2001, 02:09 PM
Great thats what i was hoping!
Old 12-06-2001, 04:42 PM
Blackfoot's Avatar
18/19 x 10.2 = 184/194
you are within spec i think.
Old 12-06-2001, 05:18 PM
Isn't the compression supposed to be the atmospheric pressure times the compression ratio?
9.7x14.7=142.6psi
Old 12-06-2001, 06:59 PM
Blackfoot's Avatar
no. check what devek says about cylinder compression as it relates to compression ratio.
Old 12-06-2001, 10:08 PM
You're the first person that I've know to be worring about too high of compresion. Its when you get the 100 psi or the dreaded 0 psi, when you start to worry.
Old 12-07-2001, 10:02 PM
I wasn't worried, I was just wondering if it meant that there was alot of carbon build up in the cylinders.
Old 12-08-2001, 08:10 AM
