Power steering rack unexpected over haul.
Well to my disgust Ive found a fairly big power steering fluid leak in my rack. Time to replace I guess.
Found what seems to be a good option on ebay, it comes with inner tie-rods and doesn't cost $1300.00 Now my question, while searching for outer tie rod ends on pelican, There doesn't seem to be a listing for a 1986 944 WITH power steering. Can I use the tie-rod ends for a 1987 944? And I just got an alignment done last week, should have left it alone I guess. I hope it wasn't their fault. Last of all, has anyone had luck with the miracle stop leaks in a bottle? I might try it so I can survive till my parts arrive, but I'm worried about it damaging my PS pump. Thanks in advance, Stephen
-1986 944 NA |
Control arms are longer on the '87. Do not believe the '87 tie rod ends would work. I know thr ends are out there, may have to call.
Look again, I just saw them on Pelican.
87 951 all stock exc. cup II's /94 968 6-spd, lowered,17in. RUF Speedlines, M030 anti- sways/ 94 968 Tip, Cup II's, otherwise stock Last edited by 968 GUY; 07-20-2010 at 05:00 PM.. |
Proprietoristicly Refined
John
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo) |
Garage Helper
I had awhile back a leak in the rack and I was also going to rebuild/replace the power steering pump at the same time, so I just ran it the way it was. There was not a single sign of fluid in the power steering reservoir. When I finally took it all apart after four weeks of having no fluid in it I was surprised that the power-steering was still working and without any noise, and very little fluid in the rack. I purchased a re-built rack and re-built the power-steering pump my self and after two years now the steering is still spot on.
+ I have heard of others who have removed the power steering pump and reservoir and ran the rack this way for extended periods of time - but that way they act like 85% of the old power-steering - a little less of power-steering, but a whole bunch better than manual steering.
78-924 traded for 80-931 traded for 84-944 traded for 85.5-944 (7th one now). ![]() UAV-M1 (Urban Assault Vehicle - Model 1) Bless the lowered, and pass the nitromethane. Pedal to the metal till you see the gates of hell then brake NLA - No longer available is a four letter word |
Hi Stephen, X10 on what John_AZ says. Buy the rebuilt rack, a NEW PS Reservoir (has a built-in filter) and a rebuild kit for the PS Pump. The PS Pump is a snap to rebuild and there is a vid on you tube that shows you how to do it. Just don't forget to draw a line down one side with a magic marker to put the two halves back together right.
Cheers, Larry |
Thanks boys.
-1986 944 NA |
