Porscaholic and loving it
wow, it's been such a long time since I've been on lol...
Anyway; I've been hunting 'bigger' brakes for my 944 N/A recently. I've heard rumor that 993TT brakes are a nice conversion setup without having to buy Brembo GTs which are essentially the same thing Porsche used (uses) on their Turbo models anyway. What I'm getting at is, what brake setup is better? The calipers look a tiny bit the same. I'm comparing the 951, 951S, and 993TT brake systems/calipers. The calipers look exactly the same form aside from ridges on the face of the 951 brakes with a more blocky 'PORSCHE' font than the more original font look on the 993TT calipers. I know they all have 4 pistons but is there any real difference that I should even be concerned about?
1984 Maroon PORSCHE 944 (Sold: Nov. 19th, 2011 )1974 Sky Blue DATSUN 260Z PORSCHE
My anti-drug <3 |
That Guy
In short i would stick with the standard 951 calipers. Cheaper rotors, cheaper pads, less weight (unsprung and rotational) and they are more than enough for the relatively lightweight / low power n/a.
Look at post #2 for info regarding the caliper differences. Note that you will need '86 951 spindles for your early offset car. http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/459467-944-brake-upgrade.html
Jon 1988 Granite Green 911 3.4L 2005 Arctic Silver 996 GT3 Past worth mentioning - 1987 924S, 1987 944, 1988 944T with 5.7L LS1 |
![]() Power though, I do plan on putting a turbocharged 968 powerplant in there soon, right around 458BHP soon enough, so will the 951 braking components be good still?
My anti-drug <3 |
Sound slike you have money to burn..Why don't you just find a nice 968, if your gonna put that engine in it...and it would look better too....
Porsche 968 = well over 5 thousand dollars Catch my drift? :P Yeah I have money to blow and while price may not be a concern, I'm not going to go crazy with it. I still want to budget and get things done at a decent price. I've seen conversion kits on eBay for as much as 2k but that included all hardware and all four calipers which I didn't think was a bad price. But I recently noticed a major price difference between 951, 951S, and 993TT brakes and was starting to wonder 'Are they physically different... or just status symbol different?' Know what I mean? Plus, I don't like the front ends on a 968, I'd rather have a 986 if anything and those things were rather ugly lol. I've just gotten stuck on 951 style front ends plus Pop-lights drive me wild lolBut back on subject. What's you're take on 951 calipers vs. 993TT calipers? The same size? or slightly thicker to fit thicker rotors?
My anti-drug <3 |
83-944 show room -sold___New ride 93-968 with SC steering wheel-ROW signal ligths- Susp M030 mods lowered,Porsche VA springs- Adjustable struts - Bilstein inserts - Bilstein sport rear -LSD -riding on Cup 1 wheels 17x8 frt 17x9.5 rear road contact Falken 452/ 225-45 ZR Front 255-40 ZR Rear -- Motor Mods /chip /K&N / mod air boxe just love the handling & power
the standard breaks on the 944 are more than adequate. most of the 944 spec guys use the standard breaks at the track. save your money.
eric |
they call their version of it 'Electronic ridecontrol®' I just think it would be neat to have a fully active suspension on a 944.As for the 3.0 powerplant, I'm using a stage III turbo system with a piggyback boost controller. With a turbine that size, 10-16psi will get you into the higher power ratings without risk of blowing up your engine. Also, I'm not going to powerup the thing and not have the body still 'blocky' I do plan on properly venting it in various places to keep the drag-co efficiency down at higher speeds. I'm doing all this myself and improvising, hence why price isn't too big of an issue for me
My anti-drug <3 |
Sorry about the misunstanding
No misunderstanding :P
I guess I should have been a tad more thorough with why I want slightly better brakes than what Porsche gave the N/A models
My anti-drug <3 |
GOOF--Like a said sorry about the misunderstanding ,your talking about Turbo Charging it not Super Charge. But by reading what you want to do I,ll say thousand & thousand of dollars,and I'm just wondering why so much peoples who turn there 968 to turbo charge successfully do it with an 8 valves motor,even outfit like (Power House had issues with there turbo 16 valves and what about Porsche itself why did they chose to go 8 valves instead of 16 in their 968 turbo. I still don't understand using a 968 motor to acheive the HP claim of 458 when it will be so simple to use a 951 8 valves. You must have a lot of money to throw away & lot of time on your hand to get into such a project & can't hardly wait to see the result plus the Dino chart.Still good kuck with your project &
trying to drive it and upgrade/restore at the same time was killing me and my checking account nearly divorced me because of it :P So I'm just going to buy everything, store it all wrapped up, then once I have everything on my check list, then break down and build can begin ![]() All of this will make for a speedy rebuild, thus I can probably get it done in about 6months time given that I work in a dock with all the right tools on hand. If i do it in my parkway like I've been doing, it could take me up to a year to finish... mainly for a stupid reason... spiders
My anti-drug <3 |
That is not stupid at all. I've quit for the night because of that very reason. Or a cockroach crawls past your face while you are under the car....end of that task for the night.
1983 944 - project mode 2002 Ford F150 - every other daily driver 1976 Honda Goldwing - the other days |
But while I don't mind spiders (despite having arachnophobia so bad that if I see one big enough and it has snuck up on me, I literally get so pissed, scared, and jumpy that I start blurting random things and cursing in a combo of French and German) but yea, I don't really mind them... it's the Tree Spiders and Brown Recluse that bother me. They look exactly alike only one is aggressive, the other isn't. I've found a total of 9 Recluse on my Datsun, only 2 on the 944 so far
My anti-drug <3 |
Garage Helper
Brown Recluse Spiders are nothing compared to the Hobo Spider - That's why they call me 8 Toes... ^^^-- ^^^^^
78-924 traded for 80-931 traded for 84-944 traded for 85.5-944 (7th one now). ![]() UAV-M1 (Urban Assault Vehicle - Model 1) Bless the lowered, and pass the nitromethane. Pedal to the metal till you see the gates of hell then brake NLA - No longer available is a four letter word |
Didn't shake the ol' boots out huh?
87 951 all stock exc. cup II's /94 968 6-spd, lowered,17in. RUF Speedlines, M030 anti- sways/ 94 968 Tip, Cup II's, otherwise stock |
But seriously, it sounds like a serious spider... one that I'd probably turn ghost white if I saw one Not boots, the spiders like to hide underneath and inside the car
My anti-drug <3 |
Garage Helper
A Hobo Spider is a cousin to the Brown Recluse - both being in the Funnel Web family. It is larger, longer legs, fast, and very agressive. It looks very much like the Tree Spider/Wolf Spider (According to which you call it) a little larger with longer legs though. When it bites it is very painfull and then the bite/venom rots the flesh away much worse than even the Brown Recluse. Three months later the Docs were taking my toes off because they couldn't stop the venom from eating away at my foot.
Instead of the 997TT brakes and if one needs to go over size completly, go with Big Reds or Big Blacks as found on 928S4's - they will fit the 944 turbo spindles with a radial mount adaptor. The rotors are larger and the pistons in the calipers are also larger - bigger brakes.
even works on mice it seems as I've found dead mice in the boot area, side pocket where you can store extra things. I guess it sufficate the poor devils :PAnd as for the 928 brakes; so they are bigger huh? it does make sense though, they have to be able to stop all that car and according to Porsche it was able to do a 0-60-0 run in 9secs which isn't bad for it's time ![]() I'll look into it, thanks for the advice! ![]() One more thing... TechnoDuck mentioned something about there being a brake size comparison on this forum on 'second post' I don't get it... I've been looking and no find ![]() Edit: disregard that question about technoduck, if the link were a spider I would have spot it a long time ago (but in this case I'd go toward it this time lol)
My anti-drug <3 Last edited by Ez-Bone; 08-15-2010 at 12:59 PM.. |
I hate spiders
1984 - 944 Black / Wilwood/Brembo brakes / fresh M-474 suspension / Welt 250 lb fronts / 28 mm solid T-bars / M030 bars w Racer's Edge hardware/MSDS headers |
| Tags |
| brake conversion , brake size , brakes , brembo , turbo |
